Painting screw heads
Packard
Hudson Valley, NY
I just assumed everyone knew this trick, but yesterday I caught my friend patiently hand painting screw heads with a tiny paint brush.
This is what I showed him:
We found a discarded corrugated carton.
We used an awl to poke several holes about 1” apart.
We inserted the screws up to the head in the cardboard.
Using a rattle can, we sprayed the cardboard where the screws were inserted.
Wait for the paint to dry.
Some additional notes:
Rust oleum cut its corporate teeth producing enamel for metal.  It makes a good choice.
If it is strictly cosmetic, go straight to paint.
If it is exterior and the screws are zinc plated, a self-etching primer is a good idea.
Follow directions on the can.
I like to let the paint fully cure before using.  Multiple coats can fill the screw head and make it difficult to use.
I place the screws about 3/4” to 1” apart.  Keep them fairly close together and you use less paint.  Large bolts require more space between.
I assume most people know this, but judging from my friend’s painting, a few might not.
I use a foam sheet (some 35mm insulation offcut) when I need to spray screwheads, I find it easier to push them in than cardboard, especially when there's a large quantity.
I will try that.  Inserting the screws is the only tedious part.  I poke holes in advance with an awl.  Trying to push the screws into the corrugated, is a losing proposition.
The advantage of corrugated is that I always seem to have some around.  I will save some of the larger pieces of packing materials when I get something fragile next.
Screw them in rather than pushing, plus it stops the extra step of the awl.
Personally, I don't like painting screws, they always seem to get damaged during install and look worse.
Plating, anodizing, or even chemical blackening solutions have better staying power. Limits options though.
Using a self-etching primer will help to minimize the flaking.  It makes the surface a bit rougher for better adhesion of the primer to the metal.
Typically, my painted screw heads survive the first use.  They tend to chip if I have to remove them and re-install.
Despite everything on the labels, I’ve read it takes about 200 hours (about 8 - 9 days) for a full cure on almost all finishes.  It seems like an over-broad statement, but it is probably true of many finishes.  I try to allow a week before I put things to use just to allow a better cure.
Or just use the stainless/brass variety with an appropriate shape. The only exception being where blackened screws are needed by the design for contrast.
Always felt that screws that are visible by necessity *and* try to hide themselves by color just scream cheap/kitsch. If a screw is needed to be visible, then its quality should match the quality of the whole piece. No "hiding in plain sight" needed then.
My 2c.
