V vwdave Member Joined Apr 3, 2009 Messages 528 Jan 22, 2011 #1 will the parallel guides fit on a 55" rail if your ripping down a 48" wide sheet? Thanks
Administrator_JSVN Administrator Staff member Festool Employee Joined Jan 22, 2007 Messages 8,426 Jan 22, 2011 #2 I still can't find that original thread where I answered this but... http://festoolownersgroup.com/ask-festool/guide-rail-question/msg97536/#msg97536 Yes, you can but the parallel guide must be attached in a way that it's not fully slid into the T-slot on the guide rail. Which isn't a problem.
joiner1970 Member Joined Jun 13, 2007 Messages 3,222 Jan 22, 2011 #3 vwdave said: will the parallel guides fit on a 55" rail if your ripping down a 48" wide sheet? Thanks Click to expand... If you mean cross cutting not ripping then yes they will go on a 1400 rail to cross cut a sheet and they will work with 2 x 1400 =2800 aswell
