Pen turning question?
Zacharytanner
Hey Guys- my buddy is starting to turn and is doing pens - does anyone have a picture or plans to build a jig to hold the blanks for drilling?
Frank
What I have done is mount the drill bit in the tailstock, put the blank in between the drill bit and headstock and slowly move the tailstock forward.
Then remove the drill bit, insert the mandrel in the hole, and turn it from there.
I used two pieces of 1" x 2" wood that were hinged and have "V" cutout of each piece to make a square when they were together.  The one end was reduced in size to be use as a handle.
I use a wooden handscrew clamp.  Mark a line square to the face, clamp the blank aligned to the line and then drill from the top.  Works well for me.
neil
Ended up doing a few
