Performax 10-20 Drum Sander
TCancelleri
Performax 10-20 Plus Drum Sander. Asking $675 OBO
This compact benchtop sander from Performax (before it was purchased by Jet) will sand boards up to 3" thick and 20" wide (in 2 passes); while the aluminum sanding drum is self-cooling to protect the sanding surface from heat damage.
I used this for thicknessing guitar wood when building acoustic guitars.
Includes
The stand ($179 option)
3 extra new sandpaper wraps 80, 80, and 36 (usually $10 each).
There is a brand 80 grit wrap on the drum that I just installed.
The sander has about 10-12 hours of use on the motor. The drum is aligned and the machine is immaculate. It has a 4" dust collector port on the back to hook to your dust collection.
I also have the manual and "TUF Tool" for making paper changes easier.
I won't ship this as it's way too heavy, and palleting it up and sending freight isn't an option.  I'm located in Northern Virginia outside the Washington DC area.
