Pine Sap
jbasen
I very, very rarely use pine on a furniture project.  I just use the odd 2x4 when I need to do some sort of construction project in my home.  I just purchased some 1" x 12" pine that I'll be using in a rustic furniture project after I cover it with birch bark.  I noticed that there are a bunch of places on the lumber that have sap on them.  When I saw this on some 2x4's I used in my attic on a project a few years ago I found that the heat in the attic caused the sap to drip for several summers before it finally stopped.  So, I have 2 questions.
1) What is the best way to clean the sap from the boards?  I know I could sand it off but I expect it will quickly load up the sandpaper and I was curious if there was a better way.
2) Is there a good way to seal the wood so it can't ooze sap in warm weather; which might affect the birch bark I'll be gluing to it?
Thanks in advance for the help.
When I've needed to do this (prior to priming knots in raw wood) I've used a heat gun until no more sap bubbled out (edit: removing the sap with a putty knife), and then cleaned the surface with turpentine.
I’ve used a sharp wide chisel...think 1.5” wide. That way it has less of a tendency to dig into the softer wood that surrounds the sap.
I just tried using a heat gun and the sap just pours out of the spot in the wood where it was visible. I just pulled the gun away, wiped it up with a paper towel, and repeated the process. It did slightly char the wood a bit but I could remove most of the discoloration with a little sanding. I also tried my wife’s blow dryer but that didn’t seem to produce enough heat.
Be aware that even though I didn’t see any visible smoke this set my smoke detector off almost immediately.
Great tip.  Thanks again
Fascinating discussion. I use Spanish cedar inside my boxes as people love the smell. I find pockets of sap. I’ll try the heat gun trick.
The smoke detector issue reminded me my bachelor time in a job transition. I was in a condo in New Jersey while my wife remained in Connecticut to sell our house. I’d get home from work, start dinner, pour a cocktail, and call her. We both knew that when the smoke detector went off, my dinner was ready.
My neighbors understood I was a helpless bachelor so never complained.
