festnoob
- Jun 13, 2010
First of all let me say that I love this machine. Unfortunately, I am not putting it to good use in my small shop. I have it set up as a drum sander and it works great. All other parts are BRAND NEW. Tool has been adjust to near perfect specs. I polished all cast iron and coated with T-9 Boeshield...It's on casters so it's ready to go. All manuals available. I only had it about 4 months.
PICTURES UPON REQUEST or stop by and take a look
Product: Model 725P-153 Molder/Planer With Pro-Pack for full, Four function performance! Includes: 25-5/16- inch Molder/Planer with 7.5HP, 220V, 40-amp.,1-Phase, TEFC cutterhead motor, push button Magnetic Switch with thermal overload protection, Variable-Speed 110V, feed system Gearmotor (allows 70 to over 1,000 cuts-per-inch), set of high-speed steel Planer Knives mounted in precision-balanced, 3-knife cutterhead (head can also be used to mount molding knives), set of Steel Infeed and Outfeed Tables (extends bed length to 42-9/16"), Magnetic Depth of Cut Scale, Precision Knife Set Gauge, Operator's Manual plus training video, "600 Molding Patterns" Book, "How To Run A Molding Business" Book.
Pro-Pack Includes:
725M Accessory Shaft to mount saw blades, pattern knife holders or drum sanding kit.
700C Single Pattern Knife Holder for pattern knives up to 3-1/4" wide. Speeds production, eliminates re-setting planer blades.
725D Drum Sanding Kit with hook & loop mounting, 2 sandpaper strips (100 & 150 grit) plus oversize pulley and longer belt for correct drum speed.
725NH Dust Chute with 4-in. diameter hose connection.
725PB Super-Slick Bedboard - Space-age polymer surface cuts bed friction by 70%. Use it for planing as well as molding.
700SK Two, 5-1/2", Carbide-Tipped, Rip Saw Blades with Locking Collars.
"How To Make Curved Molding" DVD
Pro-Pack Includes:
