Planex drywall sander jumps around
NFMudder
I just purchased a PLANEX LHS 225 Drywall Sander and made my first pass on a finished wall. The sander started to bounce and destroyed the finish. What am I doing wrong? Adjusting the suction and speed didn't help.
Which abrasive and which grit? Also, that Sander has a learning curve like most tools , so practice with it on a wall that's not finished or maybe even set up a joint/compound seam to sand on a wall that you won't freak out if you struggle a bit to learn how the sander works with you.
I was using the supplied pad. I will switch to the soft pad and see if that helps. I used fine and aggressive paper with the same result. I love the quality of this tool and will keep trying until I get it right.
. Let me clarify, were you using Granat Abrasive, Saphir, or the now-discontinued Brilliant 2?  Next , the suction on the head can be adjusted two different ways, independently of the suction level dial on the main body of the sander. With a smooth surface, and fine paper , you may need to switch between a Perimeter suction or the Centered suction to see where the sander works best for you.
Next, is your vacuum adjustable for suction level like a Festool or a Fein vac?  Occasionally I will need to adjust my vac and the dial on the sander to get what I want. Most of the time, just adjusting the sander suction dial does it for me.
Handling the Sander. It's a Rotary sander, no Random Orbit, so try out how the direction of the pad can work with you or against you if you are trying to fight it.
I think for me , it's a bit like a larger, slower version of Festool's RAS 115 sander, the rotation has to be watched when you're swinging the sander left and right or up and down a wall.
You'll get it with some practice , and there are some experienced users here who can better describe what you might be running into with your Planex than me.
I did purchase the Festool self cleaner vac as well. I think my problem may have to do with going against the rotation. I will keep working at it. I have tried the Granat Abrasive and Saphir. I am a former Porter-cable user but I decided to step up my game. Thank you for the advice
There is no question you need the soft pad kit. The planex is useless without it.
The planex will sometimes jump when you go over a really I ever surface like a hump. It takes some practice but once you get the hang of it you can fly. I run 220 grit but you might want to start with 240
I have a Rotex 125 that jumps all over the place.
I have used other ones that behave fine (using the same abrasives/extractors/surfaces.
Read in to that what you will
. For what it's worth, that's the only way a Rotex 125 has behaved for me any time I have tried to sand with one. My RO 150 is more manageable.
I have been more than happy with both of my 150mm Rotex sanders.
I now only use the 125mm Rotex with 320 grit Titan to sand acrylic primer on (flat) MDF using the interface pad.
A friend has two 125mm Rotex sanders, neither of his jump around.
Only jumps for me when I move it too fast, or don't have the suction up high enough. I just removed texture from an entire cathedral ceiling, started with 80 grit and worked down to 220.
