Hi All:
Thinking about a Planex Easy for some upcoming drywall work. Unfortunately, I don't have a CT, just a Midi with an Ultimate Dust Deputy and don't have the shop space (when done) or the cashews for a bigger vac.
So here's my question: will I be able to connect the current hose that I have (27 mm dia at the tool end) to the Planex Easy? The specs are a little confusing and it mentions both 27 and 36 connection diameters:
Specifications
Idle engine speed 400 - 920 RPM
Power consumption 400 watt
Weight 8.8 lbs (4 kg)
Abrasive dia. 8.9" (225 mm)
Dust extraction connection dia. 1-7/16" (36 mm)
Interchangeable sanding pad dia. 8-1/2" (215 mm)
Length 63.00 in (1.60 m)
Max. dust extraction connection dia. 1-1/16" (27 mm)
Would I need the 36 mm hose for this pup? Any help would be appreciated!
Specifications
