Planex sanding paper question
aas
I have a Skil masters drywall sander (I don't do enough to justify a Planex!), but would like to use the Planex papers if the holes line up. The sanding heads are the same size, there are 8 holes that have a diameter of about 10,5mm and are on a diameter of about 69mm.
I have tried to search for this info online with no luck. If anyone could measure theirs, it would be greatly appreciated.
Thanks.
If the Mirka screens attach then you do not need to worry about holes.
The screens also last a long time.
The Mafell version say "By Mirka", so that gives you another choice.
I just used them on some paint and drywall plaster.
Some of the paint gummed up, but the dry plater want was eaten up quickly.
