Good afternoon.
I just started using the planex and I had some mixed results. I know it has to be operator error. I watched the Festool video setting up the planex but I still have a couple of questions involving the "vacuum support" mechanism on the planex.
1) When sanding just face on direct, I seem to have really good dust control when the vacuum support is off and the lever switch appears to be in the locked position. Icon indicates dust moving up the middle of the planex head. However, upon inspection, it seems that this is not really the case. It looks like the lever locks a position where the vacuum is able to have suction to the outer rim of the planex head. I set the vacuum control suction to "6." Is this correct?
2) When sanding inside corners, this is where I know I had operator error... :
I switched the vacuum support to the unlocked position and removed the front brush. I set the vacuum control suction to 2. But dust seemed to be flying everywhere. It seems counter to my understanding of the icon. Switching the lever to the unlocked position show the icon with what appears to be air movement on the outer diameter. Yet, the lever closes off the vacuum outer rim support.... What am I missing here? The manual is not very helpful to me. The video is short and concise. Maybe I missed something.
Thank you for your help! [smile]
