plug it cables pulling out
Caly
Over the last couple of years had the same recurring problem........cables pull out of the plug it adapter and make use quite dangerous
Try dissasembeling the plugit, near on impossible, anyhow I managed to seperate and re assemble only to find i had to cut the vulcanised plug off to get it all back together (and 2 hours of pulling and pushing)................and two days later find it was all a waste of time. I had one of those moments and with another shreaded plugit  lead it took me literally 5 mins to fix, see final pics
[member=10024]Caly[/member]
Just to let you know, when I click on the dropbox photos, this is what appears.
Error (403)
It seems you don't belong here! You should probably sign in. Check out our Help Center and forums for help, or head back to home.
ok cheers for that, it maybe because I dragged and dropped and they are still password linked..........I will sort
