glass1 said:
Often on renos I run into 15 amp breakers. My table saw and festoon vac. combo will pop the 15 amp breaker. My track saw and Ct will also on occasion pop a 15 amp breaker. So I often have to plug the respective tools into separate outlets and manually turn on the vacuum. How about an electrical pigtail that plugs into the vac and the tool but is just a feed through that than runs to another outlet, so when the tool is started it activates the vac but runs of another outlet.
Sounds interesting, but I have some thoughts on this. You'll need to plug your tool into a whole other breaker /circuit to get off that 15amp that was popping with the Vac/Tool combo. Right?...
So, you walk around with an extension cord to another room, hoping that room isn't on the same breaker as the one you're in that's giving you trouble. At this point, couldn't you just turn the vac to Manual, and run your tool off that other extension cord/circuit? I know, defeats your whole post but no new gadget needed... [unsure]
OR, Plan B, carry around a Remote Activated Outlet that you plug your Vac into for these situations and while on a ladder or scaffold, activate the vac with the remote that would easily fit in your pocket[ providing you don't lose the remote and actually have pockets as well... [embarassed]]
I like the remote activated outlet since a single Vac's pulling amperage would be within the design limits of what I've seen these 110v outlets rated at. Much lower than a Vac and Tool combo, so the outlet trick should last a long time, even if you only need it once in a Blue Moon.
What are your thoughts? [popcorn]
