Pocket Screws for 17.5MM Plywood
rinconmike
I am using a Kreg Foremam DB210 for pocket screws.  I have Baltic Birch Plywood that is 17.5mm.
I used the 3/4" setting for the fence and backed the bit off from the gauge block a hair and the screw is shy of poking out the side of the wood by around 1/32". I checked this by putting the screw in, but not attaching the second piece and instead put the second piece against the screw to check the depth.  When I screw it together and tightened it down good, it does not poke out.
I am using the 1.25" Kreg screws.
Is this ok with 1/32" cover over the tip of the screw?  I tried about a dozen tests and none poke out.
thanks,
Mike
