While creating my version of MFS rails, I needed to hold down the pieces while I sanded them. I didn't have a set of claiming elements so I had to create my own. Using a set of tall dogs, some ends that I put groves in, and a set of 6" medium Irwin clamps.
The first picture shows how two of them, working together, hold things securely to my MFT/3. To make this work I cut off a bit of the pad from the handle side of the clamp so the neck and the slide would catch the long table dog as shown in picture 2.
The third picture shows all the pieces together, The end that has a grove in it for the slide, with the clamp with the parf dog hooked in it. I keep the clamped pieces flat by rasing the clamp off the table That keep everything flat.
How strong is it? The final picture shows a piece of plywood being bent by this imitation clamping element. It's not pretty, but it was what I needed at the time to do what the clamping element does.
Enjoy;
Enjoy;
