mastercabman
- Apr 15, 2007
i went back to my woodcraft store yesterday to look at the kapex again.
i just wanted to feel the weight and to look more on the settings of the saw.i'm still not sure yet if i'm going to get this saw,it's a little hard to swallow that price!
i did notice that the saw have positive stops at 0-15-22.5-30-and 45(miter). on the bevel,just 0-45,but no stops on 31.6(miter)and no stops on the bevel setting for cutting standard 52^ crown molding.
i know that the saw has a setting to get maximum cutting capacity,and i believe you can cut 6 5/8" crown(upside down,against the fence)witch i like to cut that way better.but i've come across some crown that was too big for my saw(bosch 3915 10"slide)so i had to cut it laying flat.
but i think with the capacity of the kapex,i will be able to cut most large size crown.
i'm just curious about others that cuts large crown,do you cut laying flat a lot?
do you have/use positive stops on you saw to cut crown(bevel/miter)?
do you think the kapex should handle all of you cutting?
is it a problem for you that the kapex does not have positive stops for crown molding?
