Press Drill Low Profile Fence
Mario Turcot
I was playing with my Nova Voyager  [drooling] drill press last night, making a bunch of repetitive holes. I had 32 boards where I need to make a 6mm (1/4") hole in each corners. The center holes have to be at 10mm from both edges. I setup my fence and realized that the chuck was going to hit the fence.
[attachimg=1] (Picture is for reference only)
So I need a low profile fence to fit on that drill press table (temp). Here is what I came up with and I thought some of you guys would like to comment and/or suggest enhancement.
[attachimg=2]
The slots let the fence travel back and forth and side ways using two simple T-track bolts. I'm planning to cut it on the CNC tonight. I will be using 15mm BB. Let me know what you think  [wink]
P.S. The dark rectangle is a fictive piece of wood  [tongue]
Using your existing high fence put a piece of thick board as a packer under the job to lift it so that your chuck clears the fence.
If you can't lower the chuck, raise the workpiece by putting one or two small pieces of plywood under the workpiece.
Thanks to both of you for your suggestion.
I did not thought of raising the board and it would have worked just fine. The reason I came with the idea of a low profile fence is based on the woodpecker drill press fence. It comes with a l shape fence and a track bar fence. To me the track bar fence act as a low profile fence.
Willy, the problem is about the length of the bit. The 6mm bit I have is shorter then the fence, so raising the table do not solve the problem. But yes adding small pieces under my work will work.
Again I did not thought of your suggestion and it would have worked just fine. However for future work I want something stable and I believe a low profile fence is the way to go for my application.
Thanks again.
I keep various thickness cut offs near my press for this very purpose.
