Price Increase Coming April 1
Price Increases Effective April 1, 2014
Item # Description Price
411810 Bevel Ended Nozzle D36 $28.00
438608 Support replacement $6.00
440404 Suction brush, D36 $14.00
440406 Upholstery brush, D36 $9.00
440412 Extension tube plastic $36.00
444376 Dust Extr. Hood $12.00
447599 Extension tube aluminium $130.00
450199 Push Stick $12.00
450644 Turbo suction brush, D36 $130.00
452797 Service unit VE-CT $494.00
452829 Compressed Air Module $172.00
452877 Hose D27X 3.5 w/Adapter $80.00
452878 Hose D27x3.5m AS $115.00
452879 Hose D27x5m $90.00
452880 Hose D27x5m AS $150.00
452881 Hose D36x3.5m $95.00
452882 Hose D36x3.5m AS $155.00
452883 Hose D36x5m $115.00
452884 Hose D36x5m AS $185.00
452885 Hose D36x7m $135.00
452886 Hose D36x7m AS $225.00
452887 Hose D50x2.5m $90.00
452888 Hose D50x2.5m AS $130.00
452889 Hose D50x4m AS $115.00
452890 Hose D50x4m AS $185.00
452891 Rotating Adapter D27 $21.00
452892 Rotating Adapter D27, AS $23.00
452893 Rotating Adapter D36 $23.00
452894 Rotating Adapter D36, AS $25.00
452895 Rotating Adapter D50 $25.00
452896 Rotating Adapter D50, AS $27.00
452897 Hose Reducer D50/D36 $15.00
452898 Y-Piece With Blanking Plug $37.00
452899 Blanking Plug D50 $15.00
452900 Curved Hand Tube D36 S. Steel $55.00
452901 Curved Hand Tube D36 Poly $22.00
452902 Extension tube steel $62.00
452903 Extension tube plypropylene $26.00
452904 Crevice Nozzle D36 $8.00
452906 Interchbl. floor nozzle D36 $31.00
452907 Standard floor nozzle D36 $36.00
452908 Industrial floor nozzle D36 $145.00
452909 Workshop floor nozzle D50 $62.00
452910 Lg. Indstrl floor nozzle D50 $160.00
452911 Multi-purpose floor nozzle D36 $60.00
452912 Large crevice nozzle D50 $21.00
452921 Handle $88.00
452923 Main filter elem. 2x $36.00
452924 Wet filter elem. 2x $21.00
452925 Dirt Trap $115.00
452926 Dirt Trap $130.00
452935 Brush, Repl. D50 $22.00
452936 Retrofit kit $22.00
452937 Retrofit kit $28.00
452970 Filter bag 5x $37.00
452971 Filter bag 5x $42.00
452998 Hose hook SH-CT $42.00
453491 Chip Guard, Repl. $2.21
454757 IAS 2 adapter $144.00
454770 Industrial cleaning set $125.00
454869 Longlife filter element 2x $70.00
456737 Longlife filter bag $225.00
456738 Longlife filter bag $230.00
456745 Hose D22x3.5m $95.00
456790 Main filter elem. $26.00
456805 Wet filter element $19.00
456806 Angle Adapter $26.00
456870 Filter Bag Heavy Duty CT 22 5X $40.00
456871 Filter Bag Heavy Duty CT 33 5X $45.00
466357 Guide rail tote bag $95.00
469625 Guide bushing adaptor $25.00
469627 Guide bushing adaptor $24.00
479863 Sys insert hole drill set acc. $36.00
481523 Hole punch $36.00
482107 Connector $17.00
482778 Abr Vlies D150 A100 5X $15.00
482779 Abr Vlies D150 A280 5X $15.00
482780 Abr Vlies D150 A800 5X $15.00
483278 Parallel guide $26.00
483358 Fine adjustment $26.00
483372 Splinter guard 5x $8.00
483580 Abr Vlies 80X133 A100 5X $14.00
483581 Abr Vlies 80X133 A280 5X $14.00
483582 Abr Vlies 80X133 A800 5X $14.00
483586 Abr Vlies 115X228 A100 5X $15.00
483587 Abr Vlies 115X228 A280 5X $15.00
483588 Abr Vlies 115X228 A800 5X $15.00
483679 StickFix sanding pad 115x225 $44.00
483922 Trammel unit $26.00
484151 Abr Saphir D115 P24 25X $25.00
484152 Abr Saphir D115 P36 25X $25.00
484165 Abr Vlies D115 A100 10X $26.00
484166 Abr Vlies D115 A180 10X $26.00
484172 StickFix sanding pad hard $28.00
484173 StickFix sanding pad soft $28.00
484176 Copy Ring 13.8mm $15.00
484453 Dust Extr. Hood $26.00
484455 Table connector 1x $20.00
484507 Suction adapter repl. $16.00
484509 Chip Collection Bag $62.00
484512 Rebate depth stop $17.00
484513 Parallel stop, replacement $26.00
484515 Standard blade sol. carb. $38.00
484518 Spiral blade HSS rustic fine $38.00
484519 Spiral blade HSS rustic coarse $38.00
484520 Planer head standard HK82SD $150.00
484521 Planer head fine HK 82 RF $175.00
484522 Planer head coarse HK 82 RG $175.00
484583 Stop adapter $8.00
484727 Brush, Plastic Bristle 2X $16.00
484728 Brush, Metal Bristle 1X $16.00
484733 Spark trap $135.00
485017 Bench Unit $115.00
485018 Angle Stop $110.00
485245 Abr Saphir D115 P50 25X $25.00
485246 Abr Saphir D115 P80 25X $25.00
485298 FiberFix sanding pad soft D4.5 $31.00
485331 Planer head undulating HK82RW $175.00
485332 Spiral blade HSS rustic undul. $38.00
485647 MPE sanding pad w/edge prtc. $44.00
485648 StickFix sanding pad w/edge pr $44.00
485724 Adhesive Strip 32.8in Roll $25.00
485758 Side Stop $68.00
485759 Sliding stop flag repl. $31.00
485808 Absolute Filter $60.00
485970 Hard felt 6 $12.00
485972 Soft felt 6 $12.00
486029 Copy Ring D 10.8 $15.00
486030 Copy Ring 17mm $15.00
486031 Copy Ring 24mm $15.00
486032 Copy Ring 27mm $15.00
486033 Copy Ring 30mm $15.00
486034 Copy Ring 40mm $15.00
486052 Angle arm $47.00
486058 Edging plate $62.00
486242 Chip Deflector OF 1010 $26.00
486296 Saw blade standard 16t $57.00
486297 Saw blade fine tooth 48t $99.00
486298 Saw blade panther 14t $68.00
486299 Saw blade alu/plastic 68t $130.00
486534 Copier Scanning Set $68.00
486546 Jigsaw blade S 75/4 5x $10.00
486547 Jigsaw blade S 105/4 5x $12.00
486548 Jigsaw blade S 75/2.5 5x $10.00
486549 Jigsaw blade S75/4FS 5x $14.00
486553 Jigsaw blade HS75/4 bi 5x $19.00
486554 Jigsaw blade HS75/3 bi 5x $19.00
486556 Jigsaw blade HS60/1.2bi 5x $16.00
486557 Jigsaw blade HS60/2 bi 5x $15.00
486558 Jigsaw blade HS105/1.2bi 5x $16.00
486559 Jigsaw blade HS105/2bi 5x $19.00
486560 Jigsaw blade HM105/4.5 $26.00
486561 Jigsaw blade HM 75/4.5 $21.00
486562 Jigsaw blade R 54/G $10.00
486563 Jigsaw blade S 75/4 K 5x $10.00
486564 Jigsaw blade S 50/1.4K 5x $10.00
486962 Jigsaw blade S 75/4 25x $38.00
486963 Jigsaw blade S75/ 2.5 25x $40.00
486965 Jigsaw blade S 75/4 K 25x $38.00
487010 Guide stop $64.00
487016 Copy Ring 30mm $16.00
487017 Copy Ring 40mm $16.00
487018 Copy Ring 27mm $16.00
487019 Copy Ring 24mm $16.00
487071 Reducing sleeve standard D27 $21.00
487441 Copy Ring Set $75.00
487515 Abr Saphir 93x93 P24 25X $17.00
487518 Abr Saphir 93x93 P80 25X $17.00
487519 Abr Saphir 93x93 P100 50X $27.00
487605 Abr Vlies 93 mm A120 10X $21.00
487606 Abr Vlies 93 mm A280 10X $21.00
487721 Reducing sleeve D36 $23.00
487779 Turbo dust bag 5x $15.00
487780 Turbo filter set $25.00
487839 Edge guide $150.00
487865 Side handle $17.00
487871 Turbo dust bag 25x $40.00
487901 Antistatic Hose IAS-2-3500 $294.00
488016 Jigsaw blade HS60/1.2bi 25x $58.00
488030 Clamping Elements 2X $110.00
488036 Flat ext.-length sanding pad $19.00
488107 Abr Vlies D125 A100 5X $15.00
488108 Abr Vlies D125 A280 5X $15.00
488131 AntistaticS Hose IAS-2-7000 $413.00
488176 Antistatic Hose IAS-2-5000 $337.00
488292 Dust Extraction Hose Set $105.00
488339 Polishing felt D80 Hard 5X $34.00
488341 Polishing felt D80 Soft 5X $34.00
488342 Polishing pad $44.00
488347 Soft felt 6", 5x $36.00
488348 Hard felt 6, 5x $36.00
488418 Adapter AD-IAS 2/D36 $84.00
488438 Battery 12V 2Ah $140.00
488451 Miter Gauge $175.00
488461 Absolute Filter $60.00
488503 Carbide-Tipped Blade HM $32.00
488543 Rabbet depth stop $14.00
488544 Parallel side fence $23.00
488564 Longitudinal stop $47.00
488565 Perforated plate repl. $83.00
488566 Chip Collection Bag $52.00
488715 Sanding pad soft 2x $21.00
488716 Sanding pad hard 2x $21.00
488717 Base Plate $19.00
488752 Guide stop $40.00
488754 Fine adjustment $26.00
488755 Collet w/nut 8mm $32.00
488756 Extension table $52.00
488760 Collet w/nut 6mm $32.00
488761 Collet 1/4in $32.00
488877 Dovetail Template SZ14 $94.00
488878 Dovetail Template SZ20 $94.00
488879 FZ 6 box joint template $88.00
488880 FZ 10 box joint template $88.00
488881 Dowel Joint Temp. DS32 $85.00
488899 Base Plate and Pad $29.00
489003 Battery 12V 2.0Ah $140.00
489022 Deflector for Guide Rails $20.00
489045 Abr Vlies 100X150 A120 10X $27.00
489127 Turbo dust bag 25x $40.00
489128 Turbo dust bag $15.00
489129 Turbo dust bag set $25.00
489229 Hard fiber base runner $26.00
489252 Sanding pad 80 x 130 $27.00
489373 Keyless chuck w/ ring, repl. $50.00
489396 Perforated plate repl. $120.00
489427 Edge guide $42.00
489458 Saw blade lamin./sol.surf. 54t $120.00
489565 Extractor hood edge $20.00
489570 Clamps 120mm 2X $42.00
489571 Clamps 300mm 2X $52.00
489631 Turbo dust bag set $25.00
489790 FS-Rapid clamp w/ fixed jaw $50.00
490031 Guide stop $20.00
490118 Circle Cutter $35.00
490119 Parallel guide $35.00
490120 Splinter guard 5x $10.00
490121 Splinter guard 20x $25.00
490160 Interface pad, 2x $21.00
490161 Flat sanding pad $31.00
490162 Sanding pad 90 degree $35.00
490163 Sanding pad R6 $35.00
490164 Sanding pad R18 concave $35.00
490165 Sanding pad R25 concave $35.00
490166 Sanding pad R10 convex $35.00
490167 Sanding pad R25 convex $35.00
490178 Jigsaw blade HS75/2.5bi 5x $19.00
490180 Jigsaw blade HS155/1.2bi 5x $23.00
490181 Jigsaw blade HS60/1.4bi 5x $15.00
490256 Jigsaw blade S75/4 FS 20x $40.00
490293 FastFix right angle chuck $120.00
490294 FastFix eccentric chuck $120.00
490471 Pozidrive bit 1-25mm HiQ 3x $10.00
490472 Pozidrive bit 2-25mm HiQ 3x $10.00
490473 Pozidrive bit 3-25mm HiQ 3x $10.00
490481 Pozidrive bit 1-25mm 10x $10.00
490482 Pozidrive bit 2-25mm 10x $10.00
490483 Pozidrive bit 3-25mm 10x $10.00
490491 Phillips bit HiQ 1-25mm 3x $10.00
490492 Phillips bit HiQ 2-25mm 3x $10.00
490493 Phillips bit HiQ 3-25mm 3x $10.00
490494 Torx bit 10-25mm HiQ 3x $14.00
490495 Torx bit 15-25mm HiQ 3x $14.00
490496 Torx bit 20-25mm HiQ 3x $14.00
490497 Torx bit 25-25mm HiQ 3x $14.00
490498 Torx bit 30-25mm HiQ 3x $14.00
490499 Torx bit 40-25mm HiQ 3x $14.00
490501 Phillips bit 1-25mm 10x $10.00
490502 Phillips bit 2-25mm 10x $10.00
490503 Phillips bit 3-25mm 10x $10.00
490504 Torx bit 10-25mm 10x $10.00
490505 Torx bit 15-25mm 10x $10.00
490506 Torx bit 20-25mm 10x $10.00
490507 Torx bit 25-25mm 10x $10.00
490508 Torx bit 30-25mm 10x $10.00
490514 StickFix sanding pad soft D185 $68.00
490517 Saw blade universal 32t $78.00
490526 StickFix sanding pad ss D185 $68.00
490555 Adjustable Stop MFT $31.00
490560 Locking knob $16.00
490585 Abr Titan 2 D185 P120 100x $95.00
490586 Abr Titan 2 D185 P150 100x $95.00
490587 Abr Titan 2 D185 P180 100x $95.00
490590 Abr Titan 2 D185 P320 100x $95.00
490649 Plug-it power cord 13’ 18G $42.00
490656 Plug-it power cord 13’ 16G $44.00
490701 Systainer SYS Maxi empty $115.00
490770 Copy Ring 17mm w/flange $17.00
490771 Copy Ring 24mm $17.00
490772 Copy Ring 8.5mm $17.00
490780 Do-It-Yourself Kit $57.00
490944 Spiral bit HSS 6x16mm $31.00
490946 Spiral bit HSS 10x30mm $31.00
490960 Bit Straight/Mortise HW10X25mm $29.00
490978 Spiral bit HW 6x16mm $57.00
490980 Spiral bit HW 10x30mm $68.00
490990 Dovetail Bit HW 14.3mm 15 $36.00
490991 Dovetail Bit HSS 14.3mm 15 $26.00
490992 Dovetail Bit HW 14.3mm 15 $36.00
490995 Dovetail Bit HSS 20mm 15 $36.00
490996 Dovetail Bit HW 20mm 15 $57.00
491001 V-groove bit HW 32x16mm 90 $66.00
491026 Chamfer/Edge Trim Bit HW 24mm $57.00
491064 Dowel Drill HW 5X30mm $36.00
491065 Dowel Drill HW 3X16mm $31.00
491066 Dowel Drill HW 5X30mm $31.00
491067 Dowel Drill HW 6x30mm $31.00
491068 Dowel Drill HW 8x30mm $31.00
491069 Dowel Drill HW 10X30mm $31.00
491072 Euro-hinge boring bit HW 20mm $59.00
491077 Euro-hinge boring bit HW 35mm $78.00
491078 Straight bit HW 8x20mm $135.00
491079 Straight bit HW 10x25mm $135.00
491080 Straight bit HW 12x30mm $135.00
491082 Flush trim bit HW 19/20mm $112.00
491084 Edge trimming bit HW 30.5mm $119.00
491085 Rebating cutter HW 38mm $131.00
491152 Dovetail Template SZO 14 $156.00
491153 Dovetail Template SZO 20 $156.00
491164 Dovetail Bit HW 14.3mm 10 $36.00
491165 Dovetail Bit HW 20mm 10 $57.00
491197 Sanding pad R10 $35.00
491198 Sanding pad 88 degree $35.00
491199 Scraper $27.00
491358 Abr Titan 2 D185 P100 100X $95.00
491384 Bearing Guide 15.88 $26.00
491385 Bearing Guide D19 $26.00
491386 Rev. cutter for bit 491078 4x $57.00
491387 Rev. cutter for bit 491079 4x $57.00
491388 Rev. cutter for bit 491080 4x $57.00
491390 Rev. cutter for bit 491081 4x $57.00
491391 Cutter for 491084, 491670 4X $47.00
491392 Rev. cutter for bit 491082 4x $57.00
491393 Rev. cutter for bit 491081 4x $57.00
491427 0 Degree Horizontal Base $125.00
491469 Parallel guide $62.00
491473 Splinter guard 5x $21.00
491483 Abr Saphir D185 P36 25X $44.00
491484 Abr Saphir D185 P24 25X $46.00
491488 Abr Bri2 D185 P100 100X $54.00
491498 55" Guide Rail FS 1400 $125.00
491499 32" Guide Rail FS 800 $80.00
491500 197" Guide Rail FS 5000 $575.00
491501 118" Guide Rail FS 3000 $335.00
491503 75" Guide Rail FS 1900 $195.00
491504 42" Guide Rail FS 1080 $95.00
491522 Sortainer 4 drawers $150.00
491582 Limit Stop $12.00
491588 Combination Angle Unit FS $95.00
491594 Quick clamp, FS $38.00
491622 Guide rail FS2424/2-LR32 holes $315.00
491632 Foam insert bottom $12.00
491633 Foam Lid Insert $17.00
491638 Foam Lid Insert $6.00
491641 Systainer Lid Insert Cl. $8.00
491666 Cutter Edge Trimming HW D19/16 $47.00
491667 Cutter Chamfer HW D24/14 S8 $47.00
491668 Cutter Chamfer HW D24/12 S8 $47.00
491669 Cutter Chamfer HW D24/10 S8 $47.00
491671 Cutter Trimming HW D24/12 S8 $114.00
491672 Cutter Trimming HW D26/12 S8 $114.00
491673 Cutter Trimming HW D20/9 S8 $57.00
491741 Tool glide strip $35.00
491750 Cover Plate $57.00
491794 Replacement bit for 492522 $21.00
491861 Flat sanding pad long $26.00
491921 SYS PORT 500 Systainer Port $350.00
491922 Systainer Port 1000 $650.00
491932 Caster Set $88.00
491937 106" Guide Rail FS 2700 $310.00
491984 Sortainer 6 drawers $155.00
491985 Sortainer 9 drawers $160.00
491986 Sortainer 12 drawers $165.00
492092 Table Infeed/Outfeed Extension $250.00
492100 Sliding Table $350.00
492125 StickFix sanding pad soft D125 $35.00
492126 Sanding Pad Super Soft D125 $35.00
492127 Sanding Pad Hard D125 RO 125 $35.00
492128 Polishing Pad FastFix D125 $35.00
492135 Centrotec Chuck $35.00
492179 Copy Ring 8.5mm $17.00
492180 Copy Ring 13.8mm $17.00
492181 Copy Ring 17mm $17.00
492182 Copy Ring 24mm $17.00
492183 Copy Ring 24mm $15.00
492184 Copy Ring 27mm $15.00
492185 Copy Ring 30mm $15.00
492186 Copy Ring 40mm $15.00
492187 Centering Mandrel $31.00
492243 Parallel guide $62.00
492271 Interface Pad D125 $21.00
492280 Sanding pad soft D125 $37.00
492282 Sanding pad ssoft D125 $35.00
492348 Abr Titan 2 D150 P1200 100X $64.00
492349 Abr Titan 2 D150 P1500 100X $64.00
492363 Abr Titan 2 D125 P1200 100X $56.00
492364 Abr Titan 2 D125 P1500 100X $56.00
492365 Abr Titan 2 D125 P3000 100X $56.00
492368 Abr Platin 2 D150 S400 15X $67.00
492369 Abr Platin 2 D150 S500 15X $67.00
492370 Abr Platin 2 D150 S1000 15X $67.00
492371 Abr Platin 2 D150 S2000 15X $67.00
492372 Abr Platin 2 D150 S4000 15X $67.00
492373 Abr Platin 2 D125 S400 15X $55.00
492374 Abr Platin 2 D125 S500 15X $55.00
492375 Abr Platin 2 D125 S1000 15X $55.00
492376 Abr Platin 2 D125 S2000 15X $55.00
492377 Abr Platin 2 D125 S4000 15X $55.00
492392 Cleaning Set D27/D36 $25.00
492427 Polishing Compound MPA 11000 $24.00
492512 CE Drill Bit HSS 3mm $13.00
492513 CE Drill Bit HSS 4mm $14.00
492514 CE Drill Bit HSS 5mm $15.00
492515 CE Drill Bit HSS 6mm $16.00
492516 CE Drill Bit HSS 7mm $17.00
492517 CE Drill Bit HSS 8mm $18.00
492518 CE Drill Bit HSS 10mm $19.00
492520 CE Countersink D2-8mm $42.00
492521 CE Countersink D5-15 $42.00
492522 CE Drill Bit w/ Depth Stop $57.00
492523 CE Countersink Drill Bit 3.5mm $68.00
492524 CE Countersink Drill Bit 4.5mm $68.00
492525 CE Self-Centering Bit 5mm $78.00
492526 Centrotec Hook Driver/Adapter $16.00
492527 CE Pozidrive Bit 1-100mm 2X $20.00
492528 CE Pozidrive Bit 2-100mm 2X $20.00
492529 CE Pozidrive Bit 3-100mm 2X $20.00
492530 CE Phillips Bit 1-100mm 2X $20.00
492531 CE Phillips Bit 2-100mm 2X $20.00
492532 CE Phillips Bit 3-100mm 2X $20.00
492533 CE Torx Bit 15-100mm 2X $20.00
492534 CE Torx Bit 20-100mm 2X $20.00
492535 CE Torx Bit 25-100mm 2X $20.00
492536 CE Torx Bit 30-100mm 2X $20.00
492537 Slot bit 5.5-100mm (7/32") 2X $20.00
492538 Slot bit 6.5-100mm (1/4") 2X $20.00
492540 Centrotec Bit Extension $21.00
492574 Hard fiber base runner $47.00
492585 Dust Extr. Hood $36.00
492601 Guide stop $50.00
492610 Multi-routing template $348.00
492611 Multi-routing template $494.00
492616 Gecko guide rail adapter $26.00
492617 Gecko $70.00
492636 Edge guide $75.00
492648 Centrotec Bit Holder BHS 65mm $25.00
492668 Chamfer Bit Undercut HW 66.5mm $156.00
492722 Extension profile MFS200 2x $140.00
492723 Extension profile MFS400 2x $166.00
492724 Extension profile MFS 700 2x $229.00
492725 Extension profile 1000 2x $312.00
492726 Extension profile 2000 2x $411.00
492732 Chip Catcher $23.00
492738 Abr Titan 2 115X228 P80 50X $40.00
492739 Abr Titan 2 115X228 P100 100X $60.00
492740 Abr Titan 2 115X228 P120 100X $60.00
492741 Abr Titan 2 115X228 P150 100X $60.00
492742 Abr Titan 2 115X228 P180 100X $60.00
492743 Abr Titan 2 115X228 P220 100X $60.00
492744 Abr Titan 2 D185 P80 50X $57.00
492753 Boom Arm $325.00
492793 Abr Bri2 100X150 P40 50X $28.00
492794 Abr Bri2 100X150 P60 50X $28.00
492795 Abr Bri2 100X150 P80 50X $28.00
492796 Abr Bri2 100X150 P100 100X $40.00
492797 Abr Bri2 100X150 P120 100X $40.00
492798 Abr Bri2 100X150 P150 100X $40.00
492799 Abr Bri2 100X150 P180 100X $40.00
492800 Abr Bri2 100X150 P220 100X $40.00
492801 Abr Bri2 100X150 P240 100X $40.00
492802 Abr Bri2 100X150 P320 100X $40.00
492803 Abr Bri2 100X150 P400 100X $40.00
492804 Abr Bri2 100X150 P40 10X $10.00
492805 Abr Bri2 100X150 P80 10X $10.00
492806 Abr Bri2 100X150 P120 10X $10.00
492807 Abr Bri2 100X150 P180 10X $10.00
492818 Abr Bri2 115X228 P40 10X $12.00
492819 Abr Bri2 115X228 P80 10X $12.00
492820 Abr Bri2 115X228 P120 10X $12.00
492821 Abr Bri2 115X228 P180 10X $12.00
492822 Abr Bri2 115X228 P40 50X $35.00
492823 Abr Bri2 115X228 P60 50X $35.00
492824 Abr Bri2 115X228 P80 50X $35.00
492825 Abr Bri2 115X228 P100 100X $56.00
492826 Abr Bri2 115X228 P120 100X $56.00
492827 Abr Bri2 115X228 P150 100X $56.00
492828 Abr Bri2 115X228 P180 100X $56.00
492829 Abr Bri2 115X228 P220 100X $56.00
492830 Abr Bri2 115X228 P240 100X $56.00
492831 Abr Bri2 115X228 P320 100X $56.00
492832 Abr Bri2 115X228 P400 100X $56.00
492843 Abr Pocket StickFix P40 10X $6.00
492844 Abr Pocket StickFix P80 10X $6.00
492845 Abr Pocket StickFix P120 10X $6.00
492846 Abr Pocket StickFix P180 10X $6.00
492847 Abr Pocket StickFix 40-180 10X $6.00
492848 Abr Bri2 80X133 P40 50X $24.00
492849 Abr Bri2 80X133 P60 50X $24.00
492850 Abr Bri2 80X133 P80 50X $24.00
492851 Abr Bri2 80X133 P100 100X $38.00
492852 Abr Bri2 80X133 P120 100X $38.00
492853 Abr Bri2 80X133 P150 100X $38.00
492854 Abr Bri2 80X133 P180 100X $38.00
492855 Abr Bri2 80X133 P220 100X $38.00
492856 Abr Bri2 80X133 P240 100X $38.00
492857 Abr Bri2 80X133 P320 100X $38.00
492858 Abr Bri2 80X133 P400 100X $38.00
492859 Abr Bri2 80X133 P40 10X $8.00
492860 Abr Bri2 80X133 P80 10X $8.00
492861 Abr Bri2 80X133 P120 10X $8.00
492862 Abr Bri2 80X133 P180 10X $8.00
492879 Abr Bri2 93x93 P40 10X $7.00
492880 Abr Bri2 93x93 P80 10X $7.00
492881 Abr Bri2 93x93 P120 10X $7.00
492882 Abr Bri2 93x93 P180 10X $7.00
492883 Abr Bri2 93x93 P40 50X $20.00
492884 Abr Bri2 93x93 P60 50X $20.00
492885 Abr Bri2 93x93 P80 50X $20.00
492886 Abr Bri2 93x93 P100 100X $32.00
492887 Abr Bri2 93x93 P120 100X $32.00
492888 Abr Bri2 93x93 P150 100X $32.00
492889 Abr Bri2 93x93 P180 100X $32.00
492890 Abr Bri2 93x93 P220 100X $32.00
492891 Abr Bri2 93x93 P240 100X $32.00
492892 Abr Bri2 93x93 P320 100X $32.00
492893 Abr Bri2 93x93 P400 100X $32.00
492944 Abr Bri2 D125 P60 50X $32.00
492945 Abr Bri2 D125 P80 50X $32.00
492946 Abr Bri2 D125 P100 100X $50.00
492947 Abr Bri2 D125 P120 100X $50.00
492948 Abr Bri2 D125 P150 100X $50.00
492949 Abr Bri2 D125 P180 100X $50.00
492950 Abr Bri2 D125 P220 100X $50.00
492951 Abr Bri2 D125 P320 100X $50.00
492952 Abr Bri2 D125 P400 100X $50.00
492966 Abr Titan 2 D125 P80 50X $35.00
492967 Abr Titan 2 D125 P120 100X $56.00
492968 Abr Titan 2 D125 P150 100X $56.00
492969 Abr Titan 2 D125 P180 100X $56.00
492970 Abr Titan 2 D125 P220 100X $56.00
492971 Abr Titan 2 D125 P240 100X $56.00
492972 Abr Titan 2 D125 P320 100X $56.00
492973 Abr Titan 2 D125 P360 100X $56.00
492974 Abr Titan 2 D125 P400 100X $56.00
493021 Abr Bri2 D185 P40 50X $38.00
493023 Abr Bri2 D185 P80 50X $38.00
493024 Abr Bri2 D185 P100 100X $54.00
493046 Table widener $120.00
493047 Connector Sleeve AS $17.00
493055 Bearing Guide D19 492622 $26.00
493056 Bearing Guide D22 492662 $26.00
493057 Bearing Guide D18.5 492666 $26.00
493059 Bearing Guide D18 492672-680 $26.00
493060 Bearing Guide D12 492672-680 $26.00
493061 Bearing Guide D6 492672-680 $26.00
493062 Bearing Guide D16 492688-694 $26.00
493063 Bearing Guide D28 492668-706 $26.00
493064 Bearing Guide D39.5 492708 $26.00
493066 Finish Cleaner, 500ml $20.00
493068 Microfiber Cloth 2X $25.00
493069 Spot Sander D36 $10.00
493077 Polishing Felt Soft D125 5X $35.00
493078 Polishing Felt Hard D125 5X $35.00
493124 Abr Saphir D125 P24 25X $33.00
493125 Abr Saphir D125 P36 25X $33.00
493126 Abr Saphir D125 P50 25X $33.00
493127 Abr Saphir D125 P80 25X $33.00
493180 Chip Catcher $21.00
493232 CT Adapter Plug (Pigtail) $15.00
493233 Table widener $78.00
493296 Domino Beech 5X19X30mm 1800X $85.00
493297 Domino Beech 6X20X40mm 1140X $85.00
493298 Domino Beech 8X22X40mm 780X $85.00
493299 Domino Beech 8X22X50mm 600X $85.00
493300 Domino Beech 10X24X50mm 510X $85.00
493307 Gecko pad replacement $19.00
493309 Slot bit 4.5-25mm (3/16") 10X $10.00
493310 Slot bit 5.5-25mm (7/32") 10X $10.00
493311 Slot bit 6.5-25mm (1/4") 10X $10.00
493334 HEPA filter element $68.00
493421 Twist drill bit set D3.0/33 $10.00
493422 Twist drill bit set D3.5/39 $11.00
493423 Twist drill bit set D4.0/43 $12.00
493424 Twist drill bit set D4.5/47 $13.00
493425 Twist drill bit set D5.0/52 $14.00
493426 Twist drill bit set D5.5/57 $15.00
493427 Twist drill bit set D6.0/57 $16.00
493428 Twist drill bit set D6.5/63 $17.00
493437 Twist drill bit HSS D3 10 pc. $14.00
493438 Twist drill bit HSS D3.5 10pc. $15.00
493439 Twist drill bit HSS D4 10 pc. $16.00
493440 Twist drill bit HSS D4.5 10pc. $17.00
493441 Twist drill bit HSS D5 10pc. $18.00
493442 Twist drill bit HSS D5.5 10pc. $19.00
493443 Twist drill bit HSS D6 10pc. $20.00
493444 Twist drill bit HSS D6.5 10pc. $21.00
493487 Domino Trim Stop $68.00
493490 Domino Cutter 5mm NL20 $37.00
493491 Domino Cutter 6mm NL28 $38.00
493492 Domino Cutter 8mm NL28 $40.00
493493 Domino Cutter 10mm NL28 $41.00
493507 Gecko set $85.00
493539 FastFix depth stop chuck $120.00
493558 Boom Arm Tool Holder $60.00
493566 Guide bushing adaptor $25.00
493572 Replacement bit for 492525 $19.00
493656 Jigsaw blade S155/W 3x $16.00
493657 Abr Bri2 D125 P40 50X $32.00
493663 Abr Titan 2 D150 P40 50x $40.00
493723 StickFix sanding pad 100x150 $27.00
493816 Polishing compound MPA 8000 $31.00
493835 Sheepskin Premium D80 5X $73.00
493836 Polishing Sheepsk. Pr D125 1X $26.00
493838 Sheepskin Premium D150 1X $31.00
493840 Sheepskin Premium D180 1X $40.00
493842 Polishing sponge D80 coarse,5x $42.00
493843 Polishing SPG D125 Yw 1X $14.00
493844 Sponge coarse 20mm D5" 5x $57.00
493846 Sponge coarse 30mm D6" 5x $68.00
493849 Polishing sponge D80 med, 5x $47.00
493850 Polishing SPG D125 Or Med 1X $19.00
493851 Polishing SPG D125 Or Med 5X $62.00
493852 Sponge Orange Mid D150 1X $23.00
493854 Sponge Orange Mid D180 1X $26.00
493855 Polishing sponge D180 5X $95.00
493857 Polishing SPG D125 Bg F 1X $18.00
493860 Sponge Beige Fine D150 5X $75.00
493862 Polishing Sponge Fine D180 5X $95.00
493863 Polishing Sponge D80 Fine 5X $47.00
493864 Polishing SPG D125 Wh F 1X $19.00
493865 Polishing Sponge Fine D125 5X $62.00
493866 Fine Sponge 30mm D6 1X $23.00
493867 Fine Sponge 30mm D6 5X $78.00
493870 Sponge D80 Fine Waffle 5X $47.00
493871 Polish. SPG D125 Wh HC F 1X $19.00
493872 Polishing Sponge Fine D125 5X $62.00
493873 Sponge White Fine HC D150 1X $23.00
493874 Fine Sponge HC 30mm D6 5X $78.00
493875 Sponge White Fine HC D180 1X $26.00
493876 Polishing Sponge D180 Fine 5X $95.00
493878 Polishing SPG D125 Bl VF 1X $20.00
493879 Polishing SPG D125 Black VF 5X $65.00
493881 Sponge Black Very Fine D150 5X $85.00
493883 Sponge Black Very Fine D180 5X $95.00
493884 Sponge D80 Ext Fine Waffle 5X $52.00
493885 Polish. SPG Bl D125 VF HC 1X $21.00
493886 Polish. SPG Bl HC D125 VF 5X $68.00
493887 Sponge Black V Fine HC D150 1X $26.00
493888 Sponge Black Very Fine D150 5X $85.00
493889 Sponge Black V Fine HC D180 1X $30.00
493890 Polishing Spng. D180 V.Fine 5X $95.00
493912 Edge protector $17.00
493913 Edge Protector $19.00
494035 Abr Cristal D125 P100 100X $46.00
494036 Abr Cristal D125 P120 100X $46.00
494052 Abr Cristal 80X133 P40 10X $7.00
494053 Abr Cristal 80X133 P60 10X $7.00
494054 Abr Cristal 80X133 P80 10X $7.00
494055 Abr Cristal 80X133 P100 10X $7.00
494056 Abr Cristal 80X133 P120 10X $7.00
494057 Abr Cristal 80X133 P40 50X $21.00
494058 Abr Cristal 80X133 P60 50X $21.00
494059 Abr Cristal 80X133 P80 50X $21.00
494060 Abr Cristal 80X133 P100 100X $34.00
494061 Abr Cristal 80X133 P120 100X $34.00
494070 Hardware kit MFT 800 $130.00
494340 Guide plate $120.00
494369 Crown Stop Kapex $99.00
494370 Angle Transfer Device $160.00
494388 Hose Garage $60.00
494391 Hold down clamp $78.00
494445 Drill Bit D3.5 5X $21.00
494446 Drill Bit BSTA D4.5 5X $21.00
494460 Collet 8mm $42.00
494463 Collet 1/4in $42.00
494464 Collet w/nut 3/8in $42.00
494465 Collet 1/2in $42.00
494522 Battery 12V 3Ah NIMH $78.00
494526 Battery 15.6V 3Ah NIMH $130.00
494622 Template guide 17 mm $17.00
494623 Template guide 24 mm $17.00
494624 Template guide 27 mm $17.00
494625 Template guide 30 mm $17.00
494626 Template guide 40 mm $17.00
494627 Guide Bushing Adapter $28.00
494631 Filter bag CT 22 bulk 20x $120.00
494632 Filter bag CT 33 bulk 20x $130.00
494675 Template guide base $57.00
494677 Small bore base $57.00
494680 Edge guide parallel $88.00
494681 Guide rail base kit $120.00
494682 Table widener $88.00
494693 Clamping Kit 2X $21.00
494839 Abr Titan 2 D125 P500 100X $56.00
494847 Domino Hand Rail Fence $68.00
494859 Domino Sipo 5X19X30mm 900X $99.00
494860 Domino Sipo 6X20X40mm 570X $99.00
494861 Domino Sipo 8X22X40mm 390X $99.00
494862 Domino Sipo 8X22X50mm 300X $99.00
494863 Domino Sipo 10X24X50mm 255X $99.00
494869 Domino Sipo 5X19X30mm 300X $42.00
494870 Domino Sipo 6X20X40mm 190X $42.00
494871 Domino Sipo 8X22X40mm 130X $42.00
494872 Domino Sipo 8X22X50mm 100X $42.00
494873 Domino Sipo 10X24X50mm 85X $42.00
494938 Domino Beech 5X19X30mm 300X $21.00
494939 Domino Beech 6X20X40mm 190X $21.00
494940 Domino Beech 8X22X40mm 130X $21.00
494941 Domino Beech 8X22X50mm 100X $21.00
494942 Domino Beech 10X24X50mm 85X $21.00
495019 Hose HSK D21.5 5m $65.00
495020 SYS-Cart Systainer Cart T-LOC $85.00
495024 SYS-ToolBox $49.00
495045 Abr Titan 2 D125 P800 100X $56.00
495059 Self Adh Discs D36 2000 100X $34.00
495061 Self Adh Discs D36 2500 100X $34.00
495063 Self Adh Discs D36 3000 100X $34.00
495065 Self Adh Discs D36 5000 100X $34.00
495066 Abr Bri2 D225 P150 25X $28.00
495067 Abr Bri2 D225 P180 25X $28.00
495068 Abr Bri2 D225 P220 25X $28.00
495130 CE Stubby Brad Point Set 3-8mm $40.00
495131 CE Socket Adapter 1/4in $20.00
495133 CE Socket Adapter 3/8in $22.00
495165 1.5 Degree Horizontal Base $125.00
495166 Planex Brush Segment (repl.) $25.00
495167 Planex Brushes (repl.) $40.00
495168 Planex Sanding Pad (repl.) $99.00
495169 Planex Reach Extender $205.00
495174 Abr Saphir D225 P24 25X $70.00
495175 Abr Saphir D225 P36 25X $70.00
495182 Edge guide $57.00
495188 Rotex front handle $19.00
495207 Splinterguard Clear 1400, 55" $20.00
495209 Splinterguard Clear 5000, 197" $40.00
495223 High Gloss Wax, 500 ML $25.00
495228 Centrotec Hand Driver $20.00
495246 Plexiglas template routing aid $317.00
495247 Rod, 2 each $26.00
495339 Template guide 1/2" OD OF 2200 $17.00
495340 Template guide 3/4" OD OF 2200 $17.00
495341 Template guide 1" OD OF 2200 $17.00
495342 Template guide 1 3/8" OF 2200 $17.00
495372 Saw blade panther 14t TS 55 $45.00
495377 Saw blade fine tooth 48t $73.00
495378 Saw blade panther 16t TS 75 $73.00
495379 Saw blade standard, 18t $78.00
495380 Saw blade universal 36t $83.00
495381 Saw blade fine tooth 52t $120.00
495382 Saw blade laminate 60t $130.00
495383 Saw blade alu/plastic 72t $166.00
495384 Saw blade steel 36t $109.00
495385 Saw blade aluminum 68 tooth $140.00
495386 Saw blade laminate 64 tooth $140.00
495387 Saw blade fine tooth 80 tooth $146.00
495388 Saw blade universal 60 tooth $135.00
495415 Tape measure mm/inch $25.00
495462 Multifunction table MFT/3 $645.00
495502 Cross Member MFT/3 2X $75.00
495544 Perforated top $135.00
495565 MFT/3-MINI $445.00
495623 Hard pad FastFix D3.5 $31.00
495625 Polishing Pad $31.00
495648 Routing slide $161.00
495661 Domino Beech 4X17X20mm 450X $21.00
495663 Domino Cutter 4mm NL11 $36.00
495666 Support bracket $31.00
495717 Parallel Side Fence $270.00
495718 Parallel guide extension $150.00
495747 Wallpaper Perforator TP 220 $155.00
495802 Handle $88.00
495886 Service Unit $478.00
495888 MFT/3 Basic $545.00
495929 Abr Bri2 D225 P80 25X $28.00
495930 Abr Bri2 D225 P100 25X $28.00
495931 Abr Bri2 D225 P120 25X $28.00
495932 Abr Bri2 D225 P240 25X $28.00
495939 Dry guide coat HB-Set $30.00
495940 Refill Cartridge 2X30g $18.00
495964 Planex CT Mount $120.00
495965 Hand sanding block soft $25.00
495966 Hand sanding block hard $25.00
495967 Hand sanding block hard $25.00
495989 Abr Bri2 D125 P40 10X $10.00
495990 Abr Bri2 D125 P60 10X $12.00
495991 Abr Bri2 D125 P80 10X $12.00
495992 Abr Bri2 D125 P120 10X $12.00
495993 Abr Bri2 D125 P180 10X $12.00
495994 Abr Bri2 D125 P320 10X $12.00
496001 Abr Cristal D125 P40 10X $10.00
496004 Abr Cristal D125 P100 10X $10.00
496005 Abr Cristal D125 P120 10X $10.00
496006 Abr Bri2 115X228 P60 10X $12.00
496008 Abr Bri2 80X133 P60 10X $8.00
496010 Abr Bri2 100X150 P60 10X $10.00
496011 Abr Bri2 93x93 P 60 10X $7.00
496106 Planex Sanding Pad Set $110.00
496111 Rollers 2X $50.00
496120 Longlife filter bag $205.00
496121 Longlife filter bag $225.00
496122 Tool holder $55.00
496134 Angle Base $105.00
496140 Planex Interface Pad 2X $47.00
496141 Compressed Air Module $198.00
496144 StickFix sanding pad ss D150 $44.00
496147 StickFix sanding pad soft D150 $44.00
496149 StickFix sanding pad hard D150 $44.00
496151 StickFix polishing pad D150 $44.00
496152 Polishing pad D6 $44.00
496169 Wet filter element $21.00
496170 Main flter elem. $36.00
496172 Filter Element HP CT AC $52.00
496186 SELFCLEAN filter bag 5x $42.00
496187 SELFCLEAN filter bag 5x $37.00
496215 Disposable Liner CT-AC 5X $42.00
496300 Polishing Compound MPA 9000 $28.00
496304 Saw Blade Universal 28t $52.00
496305 Saw Blade Standard 12t $47.00
496307 Saw Blade Alu/Plastic 56t $94.00
496309 Saw Blade Lamin./Sol.Surf. 48t $83.00
496336 Abr Cristal 93x93 P40 10X $6.00
496337 Abr Cristal 93x93 P60 10X $6.00
496338 Abr Cristal 93x93 P80 10X $6.00
496339 Abr Cristal 93x93 P100 10X $6.00
496340 Abr Cristal 93x93 P120 10X $6.00
496341 Abr Cristal 93x93 P40 50X $18.00
496342 Abr Cristal 93x93 P60 50X $18.00
496343 Abr Cristal 93x93 P80 50X $18.00
496344 Abr Cristal 93x93 P100 100X $28.00
496345 Abr Cristal 93x93 P120 100X $28.00
496347 Abr Cristal 100X150 P60 10X $8.00
496348 Abr Cristal 100X150 P80 10X $8.00
496349 Abr Cristal 100X150 P100 10X $8.00
496350 Abr Cristal 100X150 P120 10X $8.00
496351 Abr Cristal 100X150 P40 50X $24.00
496352 Abr Cristal 100X150 P60 50X $24.00
496354 Abr Cristal 100X150 P100 100X $36.00
496355 Abr Cristal 100X150 P120 100X $36.00
496368 Abr Titan 2 D150 P3000 100X $64.00
496370 Onboard Nozzle and Tube Holder $26.00
496373 Onboard Nozzles Holder $20.00
496450 CE Adapter for 3-Jaw Chucks $20.00
496508 Abr Polish Vlies D150 Gr 10X $22.00
496509 Abr Polish Vlies D150 Wh 10X $22.00
496510 Abr Polish Vlies D125 Gr 10X $20.00
496511 Abr Polish Vlies D125 Wh 10X $20.00
496512 Abr Diamant D150 D500 2X $28.00
496513 Abr Diamant D150 D1000 2X $28.00
496514 Abr Diamant D150 D2000 2X $28.00
496515 Abr Diamant D150 D3000 2X $28.00
496520 Abr Diamant D80 D500 4X $33.00
496521 Abr Diamant D80 D1000 4X $33.00
496522 Abr Diamant D80 D2000 4X $33.00
496523 Abr Diamant D80 D3000 4X $33.00
496579 Abr Bri2 D150 P40 10X $14.00
496580 Abr Bri2 D150 P60 10X $14.00
496581 Abr Bri2 D150 P80 10X $14.00
496582 Abr Bri2 D150 P120 10X $14.00
496583 Abr Bri2 D150 P180 10X $14.00
496584 Abr Bri2 D150 P320 10X $14.00
496585 Abr Bri2 D150 P40 50X $38.00
496586 Abr Bri2 D150 P60 50X $38.00
496587 Abr Bri2 D150 P80 50X $38.00
496588 Abr Bri2 D150 P100 100X $58.00
496589 Abr Bri2 D150 P120 100X $58.00
496590 Abr Bri2 D150 P150 100X $58.00
496591 Abr Bri2 D150 P180 100X $58.00
496592 Abr Bri2 D150 P220 100X $58.00
496593 Abr Bri2 D150 P240 100X $58.00
496594 Abr Bri2 D150 P320 100X $58.00
496595 Abr Bri2 D150 P400 100X $58.00
496597 Abr Cristal D150 P60 10X $12.00
496598 Abr Cristal D150 P80 10X $12.00
496599 Abr Cristal D150 P100 10X $12.00
496600 Abr Cristal D150 P120 10X $12.00
496605 Abr Cristal D150 P120 100X $52.00
496620 Abr Saphir D150 P24 5X $15.00
496621 Abr Saphir D150 P36 5X $15.00
496622 Abr Saphir D150 P50 5X $15.00
496623 Abr Saphir D150 P80 5X $15.00
496624 Abr Saphir D150 P24 25X $36.00
496625 Abr Saphir D150 P36 25X $36.00
496626 Abr Saphir D150 P50 25X $36.00
496627 Abr Saphir D150 P80 25X $36.00
496628 Abr Saphir D150 P100 25X $35.00
496629 Abr Titan 2 D150 P40 50X $42.00
496630 Abr Titan 2 D150 P60 50X $42.00
496631 Abr Titan 2 D150 P80 50X $42.00
496632 Abr Titan 2 D150 P100 100X $64.00
496633 Abr Titan 2 D150 P120 100X $64.00
496634 Abr Titan 2 D150 P150 100X $64.00
496635 Abr Titan 2 D150 P180 100X $64.00
496636 Abr Titan 2 D150 P220 100X $64.00
496637 Abr Titan 2 D150 P240 100X $64.00
496638 Abr Titan 2 D150 P280 100X $64.00
496639 Abr Titan 2 D150 P320 100X $64.00
496640 Abr Titan 2 D150 P360 100X $64.00
496641 Abr Titan 2 D150 P400 100X $64.00
496642 Abr Titan 2 D150 P500 100X $64.00
496643 Abr Titan 2 D150 P800 100X $64.00
496647 Interface Pad Soft D150 $24.00
496752 HEPA filter element $62.00
496780 Boom Arm Support Bracket $35.00
496801 Edge protector (repl.) $16.00
496802 Triangular sanding pad plate $31.00
496803 Triangular extended plate $31.00
496804 Soft pad FastFix D3.5 $31.00
496905 FastFix keyless chuck, repl. $70.00
496911 Planex Harness $225.00
496929 IAS 2 Double adapter $213.00
496932 Bit box 10pc Assort 8X $110.00
496936 Bit box 10pc. assort $12.00
496938 Guide Rail Index $28.00
496939 Guide Rail FS1400-LR32 Holes $125.00
496942 Wood-Drill-Set 1/8"-1/2" $125.00
496962 Hand Sanding Block 80X130 $65.00
496963 Hand Sanding Block 115X226 $125.00
496964 Hand Sanding Block 80X400 $135.00
496965 Hand Sanding Block 80X200 $95.00
496972 Hose D 36x3.5M for Planex $165.00
496975 Abr Granat D150 P40 50X $40.00
496976 Abr Granat D150 P60 50X $40.00
496977 Abr Granat D150 P80 50X $40.00
496978 Abr Granat D150 P100 100X $62.00
496979 Abr Granat D150 P120 100X $62.00
496980 Abr Granat D150 P150 100X $62.00
496981 Abr Granat D150 P180 100X $62.00
496982 Abr Granat D150 P220 100X $62.00
496983 Abr Granat D150 P240 100X $62.00
496984 Abr Granat D150 P280 100X $62.00
496985 Abr Granat D150 P320 100X $62.00
496986 Abr Granat D150 P360 100X $62.00
496987 Abr Granat D150 P400 100X $62.00
496988 Abr Granat D150 P500 100X $62.00
496989 Abr Granat D150 P800 50X $40.00
496990 Abr Granat D150 P1000 50X $40.00
496991 Abr Granat D150 P1200 50X $40.00
496992 Abr Granat D150 P1500 50X $40.00
497088 Abr Vli Fine 320 115x152 $30.00
497089 Abr Vli Ultrafine 800 115x152 $30.00
497090 Abr Vli Ultrafine 1000 115x152 $30.00
497091 Abr Roll Granat 115X25M P120 $65.00
497092 Abr Roll Granat 115X25M P150 $65.00
497093 Abr Roll Granat 115X25M P180 $65.00
497094 Abr Roll Granat 115X25M P240 $60.00
497095 Abr Roll Granat 115X25M P320 $60.00
497096 Abr Roll Granat 115X25M P400 $60.00
497097 Abr Roll Granat 115X25M P500 $60.00
497098 Abr Roll Granat 115X25M P600 $60.00
497117 Abr Granat 80X133 P40 50X $25.00
497118 Abr Granat 80X133 P60 50X $25.00
497119 Abr Granat 80X133 P80 50X $25.00
497120 Abr Granat 80X133 P120 100X $41.00
497121 Abr Granat 80X133 P150 100X $41.00
497122 Abr Granat 80X133 P180 100X $41.00
497123 Abr Granat 80X133 P220 100X $41.00
497124 Abr Granat 80X133 P240 100X $41.00
497125 Abr Granat 80X133 P320 100X $41.00
497126 Abr Granat 80X133 P400 100X $41.00
497127 Abr Granat 80X133 P40 10X $9.00
497128 Abr Granat 80X133 P80 10X $9.00
497129 Abr Granat 80X133 P120 10X $9.00
497130 Abr Granat 80X133 P180 10X $9.00
497131 Abr Granat 100X150 P40 10X $10.00
497132 Abr Granat 100X150 P80 10X $10.00
497133 Abr Granat 100X150 P120 10X $10.00
497134 Abr Granat 100X150 P180 10X $10.00
497135 Abr Granat 100X150 P40 50X $29.00
497136 Abr Granat 100X150 P60 50X $29.00
497137 Abr Granat 100X150 P80 50X $29.00
497138 Abr Granat 100X150 P120 100X $44.00
497139 Abr Granat 100X150 P150 100X $44.00
497140 Abr Granat 100X150 P180 100X $44.00
497141 Abr Granat 100X150 P220 100X $44.00
497142 Abr Granat 100X150 P240 100X $44.00
497143 Abr Granat 100X150 P320 100X $44.00
497144 Abr Granat 100X150 P400 100X $44.00
497145 Abr Granat D125 P40 10X $12.00
497146 Abr Granat D125 P60 10X $12.00
497147 Abr Granat D125 P80 10X $12.00
497148 Abr Granat D125 P120 10X $12.00
497149 Abr Granat D125 P180 10X $12.00
497150 Abr Granat D125 P320 10X $12.00
497151 Abr Granat D150 P40 10X $14.00
497152 Abr Granat D150 P60 10X $14.00
497153 Abr Granat D150 P80 10X $14.00
497154 Abr Granat D150 P120 10X $14.00
497155 Abr Granat D150 P180 10X $14.00
497156 Abr Granat D150 P320 10X $14.00
497159 Abr STF 80X400 P 80 GR 50X $53.00
497160 Abr Granat 80X400 P120 50X $53.00
497162 Abr Granat 80X400 P180 50X $53.00
497163 Abr Granat 80X400 P240 50X $53.00
497164 Abr Granat 80X400 P320 50X $53.00
497165 Abr Granat D125 P40 50X $34.00
497166 Abr Granat D125 P60 50X $34.00
497167 Abr Granat D125 P80 50X $34.00
497168 Abr Granat D125 P100 100X $54.00
497169 Abr Granat D125 P120 100X $54.00
497170 Abr Granat D125 P150 100X $54.00
497171 Abr Granat D125 P180 100X $54.00
497172 Abr Granat D125 P220 100X $54.00
497173 Abr Granat D125 P240 100X $54.00
497174 Abr Granat D125 P280 100X $54.00
497175 Abr Granat D125 P320 100X $54.00
497176 Abr Granat D125 P360 100X $54.00
497177 Abr Granat D125 P400 100X $54.00
497178 Abr Granat D125 P500 100X $54.00
497179 Abr Granat D125 P800 50X $34.00
497180 Abr Granat D125 P1000 50X $34.00
497181 Abr Granat D125 P1200 50X $34.00
497182 Abr Granat D125 P1500 50X $34.00
497185 Abr D185/16 P80 GR 50X $55.00
497186 Abr D185/16 P120 GR 100X $95.00
497188 Abr D185/16 P180 GR100X $95.00
497203 Abr 80X400 P 280 GR 50X $53.00
497204 Abr Granat 80X133 P280 100X $41.00
497216 Keyless chuck, replacement $65.00
497295 Handle CT 48 $88.00
497297 Standard Plastic Base Plate $16.00
497298 Dimple Base Plate $23.00
497299 Hard Fiber Base Plate $23.00
497300 Steel Insert Base Plate $21.00
497301 Base plate w/Stickfix $22.00
497303 Guide Rail Adapter $25.00
497304 Circle Cutter $47.00
497351 Kapex Mobile Base UG $515.00
497352 Right Ext. For Mobile Base UG $312.00
497353 Left Ext. For Mobile Base UG $312.00
497354 Kapex Portable Stand UG Set $858.00
497363 Abr Granat D90 P40 50X $26.00
497364 Abr Granat D90 P60 50X $26.00
497365 Abr Granat D90 P80 50X $26.00
497366 Abr Granat D90 P100 100X $39.00
497367 Abr Granat D90 P120 100X $39.00
497368 Abr Granat D90 P150 100X $39.00
497369 Abr Granat D90 P180 100X $39.00
497370 Abr Granat D90 P220 100X $39.00
497371 Abr Granat D90 P240 100X $39.00
497372 Abr Granat D90 P320 100X $39.00
497373 Abr Granat D90 P400 100X $39.00
497379 Abr Bri2 D90 P40 50X $25.00
497380 Abr Bri2 D90 P60 50X $25.00
497381 Abr Bri2 D90 P80 50X $25.00
497382 Abr Bri2 D90 P100 100X $37.00
497383 Abr Bri2 D90 P120 100X $37.00
497384 Abr Bri2 D90 P150 100X $37.00
497385 Abr Bri2 D90 P180 100X $37.00
497386 Abr Bri2 D90 P220 100X $37.00
497387 Abr Bri2 D90 P240 100X $37.00
497388 Abr Bri2 D90 P320 100X $37.00
497389 Abr Bri2 D90 P400 100X $37.00
497390 Abr Granat 93x93 P40 50X $21.00
497391 Abr Granat 93x93 P60 50X $21.00
497392 Abr Granat 93x93 P80 50X $21.00
497393 Abr Granat 93x93 P100 100X $33.00
497394 Abr Granat 93x93 P120 100X $33.00
497395 Abr Granat 93x93 P150 100X $33.00
497396 Abr Granat 93x93 P180 100X $33.00
497397 Abr Granat 93x93 P220 100X $33.00
497398 Abr Granat 93x93 P240 100X $33.00
497399 Abr Granat 93x93 P320 100X $33.00
497400 Abr Granat 93x93 P400 100X $33.00
497401 Abr Vlies D90 A80 10X $21.00
497402 Abr Vlies D90 A100 10X $21.00
497403 Abr Vlies D90 A280 10X $21.00
497404 Abr Vlies D90 S800 10X $21.00
497405 Abr Granat D77 P80 50X $35.00
497406 Abr Granat D77 P120 50X $35.00
497407 Abr Granat D77 P150 50X $35.00
497408 Abr Granat D77 P180 50X $35.00
497409 Abr Granat D77 P240 50X $35.00
497410 Abr Granat D77 P280 50X $35.00
497411 Abr Granat D77 P320 50X $35.00
497412 Abr Granat D77 P400 50X $35.00
497413 Abr Granat D77 P500 50X $35.00
497425 Abr Platin 2 D80 S400 15X $35.00
497426 Abr Platin 2 D80 S500 15X $35.00
497427 Abr Platin 2 D80 S1000 15X $39.00
497443 Circle Cutter/ Guide Adapter $62.00
497444 Replacement Felt $12.00
497472 Shelf, rotary $83.00
497473 Double Hook Universal $57.00
497474 Double Hook for Tool Rest $57.00
497475 Single prong hook $21.00
497476 Profile key fastener $11.00
497477 Shelf, adjustable $50.00
497481 Interface pad $19.00
497483 Backing - Thin Triangular Pad $19.00
497497 Charger MXC $135.00
497514 UG Extension Set (L+R ext.) $545.00
497525 Spot Repair Scraper $65.00
497539 SelfClean Filter Bag CT 48 5X $47.00
497563 Systainer SYS 1 empty $65.00
497564 Systainer SYS 2 empty $70.00
497565 Systainer SYS 3 empty $75.00
497566 Systainer SYS 4 empty $80.00
497567 Systainer SYS 5 empty $90.00
497655 Accessory Kit Metric $365.00
497656 Accessory Kit Imperial $365.00
497657 Guide Rail Accessory Kit $210.00
497658 Tool Organizer, SYS HWZ $155.00
497683 Abr Systainer SYS-STF D115 TL $80.00
497684 Abr Sys. SYS-STF 80X133 TL $80.00
497685 Abr Systainer SYS-STF D125 TL $80.00
497686 Abr Sys. SYS-STF 100X150 TL $80.00
497687 Abr Systainer SYS-STF D90 TL $80.00
497688 Abr Sys. SYS-STF 115X228 TL $85.00
497690 Abr Systainer SYS-STF D150 TL $90.00
497692 Systainer SYS 1 Uni $80.00
497693 Systainer SYS 1 Vari $80.00
497694 Systainer SYS 1 Box $80.00
497695 Systainer SYS-OF D8/D12 $85.00
497696 Systainer SYS 2 Vari $85.00
497697 Compact Cleaning Set T-Loc $88.00
497700 Cleaning set f tradesmen $240.00
497701 Cleaning set f workshop $270.00
497702 Cleaning set universal $165.00
497709 Carvex Accessory Systainer $200.00
497850 Abr Granat D90 P280 100X $39.00
497855 Clear Window for TL SYS 10X $8.00
497856 Auxiliary Handle TL SYS 1-2 $15.00
497868 Domino Cutter 8mm NL 50 $52.00
497869 Domino Cutter 10mm NL 50 $54.00
497870 Domino Cutter 12mm NL 50 $56.00
497871 Domino Cutter 14mm NL 50 $58.00
497877 Foam insert set $26.00
497878 Diced Foam Insert for SYS Vari $15.00
497926 CT AC Blast Gate $57.00
497936 Window protector set (S, M, L) $32.00
497951 Right angle attachment $90.00
497964 Abr Roll Granat P800 115X25M $65.00
498038 Plastic container red 12x TL $16.00
498039 Plastic container yellow 6x TL $12.00
498040 Plastic container blue 3x TL $8.00
498041 Plastic container green 2x TL $8.00
498042 Org Container Orange TL 2X $11.00
498044 Foam lid insert, soft $6.00
498060 Heavy Duty Oil Applicator 0.3L $35.00
498061 One Step Oil Applicator 0.3L $35.00
498062 Outdoor Oil Applicator 0.3L $35.00
498063 Finish Applicator Set $145.00
498064 Heavy Duty Oil 0.3L 2X $30.00
498065 One Step Oil 0.3L 2X $30.00
498066 Outdoor Oil 0.3L 2X $30.00
498067 Heavy Duty Oil 5L $125.00
498068 One-step Oil 5L $125.00
498069 Outdoor Oil 5L $125.00
498070 Applicator Sponge $21.00
498071 Cleaning cloth 240x380 mm $25.00
498204 Domino Asst. Sys 8/10 $285.00
498205 Domino Asst. Sys 12/14 $260.00
498212 Domino Beech 8X80 190X $52.00
498213 Domino Beech 8X100 150X $52.00
498214 Domino Beech 10X80 150X $52.00
498215 Domino Beech 10X100 120X $52.00
498216 Domino Beech 12X100 100X $52.00
498217 Domino Beech 12X140 90X $52.00
498218 Domino Beech 14X100 80X $52.00
498219 Domino Beech 14X140 70X $52.00
498233 Adapter $50.00
498297 Abr Saphir 93x93 P36 25X $17.00
498298 Abr Saphir 93x93 P50 25X $17.00
498322 Abr Pla2 D90 S500 15X $52.00
498323 Abr Pla2 D90 S1000 15X $52.00
498324 Abr Pla2 D90 S2000 15X $52.00
498325 Abr Pla2 D90 S4000 15X $52.00
498326 Abr Granat D90 P500 100X $39.00
498327 Abr Granat D90 P800 50X $26.00
498328 Abr Granat D90 P1000 50X $26.00
498329 Abr Granat D90 P1200 50X $26.00
498330 Abr Granat D90 P1500 50X $26.00
498337 Battery 12v 1.5Ah Li-Ion $75.00
498339 Battery 12V 3.0Ah Li-Ion $85.00
498341 Battery 15V 3.0Ah Li-Ion $100.00
498361 Spray gun hook $52.00
498410 SELFCLEAN filter bag, 5x $27.00
498411 SELFCLEAN filter bag, 5x $32.00
498506 Longlife Filter Bag CT 48 $245.00
498507 Work Center WCR 1000 $375.00
498527 Universal brush nozzle D36 $17.00
498568 SysLite KAL 100 Worklamp $175.00
498590 Domino Cross Stop $68.00
498617 Battery 10.8v 1.5Ah Li-Ion $95.00
498660 SYS-Roll 100 Hand Truck $175.00
498686 Domino Beech 8X750 36X $68.00
498687 Domino Beech 10X750 28X $68.00
498688 Domino Beech 12X750 22X $68.00
498689 Domino Beech 14X750 18X $68.00
498690 Domino Sipo 8X750 36X $99.00
498691 Domino Sipo 10X750 28X $99.00
498692 Domino Sipo 12X750 22X $99.00
498693 Domino Sipo 14X750 18X $99.00
498694 StickFix sanding Pad Soft D77 $45.00
498796 Centrotec Install Set -Dr Bits $425.00
498886 Chuck keyless 13mm $60.00
498889 Domino Asst. Sys - Empty $85.00
498899 Domino Asst. Sys 4/5/6/8/10 $285.00
498917 Phillips Impact 2-25mm 5X $15.00
498918 Phillips Impact 3-25mm 5X $15.00
498921 Torx Impact 20-25mm 5X $16.00
498922 Torx Impact 25-25mm 5X $16.00
498923 Torx Impact 30-25mm 5X $16.00
498924 Torx Impact 40-25mm 5X $16.00
498929 Abr Granat D77 P800 50X $35.00
498930 Abr Granat D77 P1000 50X $35.00
498931 Abr Granat D77 P1200 50X $35.00
498932 Abr Granat D77 P1500 50X $35.00
498944 Abr Granat 115X228 P40 50X $36.00
498945 Abr Granat 115X228 P60 50X $36.00
498946 Abr Granat 115X228 P80 50X $36.00
498947 Abr Granat 115X228 P120 100X $60.00
498948 Abr Granat 115X228 P150 100X $60.00
498949 Abr Granat 115X228 P180 100X $60.00
498950 Abr Granat 115X228 P220 100X $60.00
498951 Abr Granat 115X228 P240 100X $60.00
498952 Abr Granat 115X228 P280 100X $60.00
498953 Abr Granat 115X228 P320 100X $60.00
498954 Abr Granat 115X228 P400 100X $60.00
498968 Pegboard hook H LWH HSK-A $38.00
498974 Impact CE Mag. Bit Holder BH60 $22.00
498986 Fusion-Tec MJ Pad SS D150 $42.00
498987 Fusion-Tec MJ Pad Soft D150 $44.00
498988 Fusion-Tec MJ Pad Hard D150 $42.00
498994 Filter Element CT26/36/48 HEPA $85.00
499011 Splinterguard 5X $20.00
499021 Polishing compound MPA 5000 $37.00
499030 Abr Rub2 115x228 P40 50X $30.00
499031 Abr Rub2 115x228 P60 50X $30.00
499032 Abr Rub2 115x228 P80 50X $30.00
499033 Abr Rub2 115x228 P100 50X $30.00
499034 Abr Rub2 115x228 P120 50X $30.00
499035 Abr Rub2 115x228 P150 50X $30.00
499036 Abr Rub2 115x228 P180 50X $30.00
499037 Abr Rub2 115x228 P220 50X $30.00
499038 Abr Rub2 115x228 P40 10X $10.00
499039 Abr Rub2 115x228 P60 10X $10.00
499040 Abr Rub2 115x228 P80 10X $10.00
499041 Abr Rub2 115x228 P100 10X $10.00
499042 Abr Rub2 115x228 P120 10X $10.00
499043 Abr Rub2 115x228 P150 10X $10.00
499044 Abr Rub2 115x228 P180 10X $10.00
499045 Abr Rub2 115x228 P220 10X $10.00
499046 Abr Rub2 80x133 P40 50X $21.00
499047 Abr Rub2 80X133 P60 50X $21.00
499048 Abr Rub2 80X133 P80 50X $21.00
499049 Abr Rub2 80X133 P100 50X $21.00
499050 Abr Rub2 80X133 P120 50X $21.00
499051 Abr Rub2 80X133 P150 50X $21.00
499052 Abr Rub2 80X133 P180 50X $21.00
499053 Abr Rub2 80x133 P220 50X $21.00
499054 Abr Rub2 80x133 P40 10X $7.00
499055 Abr Rub2 80X133 P60 10X $7.00
499056 Abr Rub2 80X133 P80 10X $7.00
499057 Abr Rub2 80X133 P100 10X $7.00
499058 Abr Rub2 80X133 P120 10X $7.00
499059 Abr Rub2 80x133 P150 10X $7.00
499060 Abr Rub2 80x133 P180 10X $7.00
499061 Abr Rub2 80x133 P220 10X $7.00
499077 Abr Rub2 D90 P40 50X $22.00
499078 Abr Rub2 D90 P60 50X $22.00
499079 Abr Rub2 D90 P80 50X $22.00
499080 Abr Rub2 D90 P100 50X $22.00
499081 Abr Rub2 D90 P120 50X $22.00
499082 Abr Rub2 D90 P150 50X $22.00
499083 Abr Rub2 D90 P180 50X $22.00
499084 Abr Rub2 D90 P220 50X $22.00
499085 Abr Rub2 D115 P40 50X $24.00
499086 Abr Rub2 D115 P60 50X $24.00
499087 Abr Rub2 D115 P80 50X $24.00
499088 Abr Rub2 D115 P100 50X $24.00
499089 Abr Rub2 D115 P120 50X $24.00
499090 Abr Rub2 D115 P150 50X $24.00
499091 Abr Rub2 D115 P180 50X $24.00
499092 Abr Rub2 D115 P220 50X $24.00
499093 Abr Rub2 D125 P40 50X $28.00
499094 Abr Rub2 D125 P60 50X $28.00
499095 Abr Rub2 D125 P80 50X $28.00
499096 Abr Rub2 D125 P100 50X $28.00
499097 Abr Rub2 D125 P120 50X $28.00
499098 Abr Rub2 D125 P150 50X $28.00
499099 Abr Rub2 D125 P180 50X $28.00
499100 Abr Rub2 D125 P220 50X $28.00
499101 Abr Rub2 D125 P40 10X $10.00
499102 Abr Rub2 D125 P60 10X $10.00
499103 Abr Rub2 D125 P80 10X $10.00
499104 Abr Rub2 D125 P100 10X $10.00
499105 Abr Rub2 D125 P120 10X $10.00
499106 Abr Rub2 D125 P150 10X $10.00
499107 Abr Rub2 D125 P180 10X $10.00
499108 Abr Rub2 D125 P220 10X $10.00
499109 Abr Rub2 D150 P40 10X $12.00
499110 Abr Rub2 D150 P60 10X $12.00
499111 Abr Rub2 D150 P80 10X $12.00
499112 Abr Rub2 D150 P100 10X $12.00
499113 Abr Rub2 D150 P120 10X $12.00
499114 Abr Rub2 D150 P150 10X $12.00
499115 Abr Rub2 D150 P180 10X $12.00
499116 Abr Rub2 D150 P220 10X $12.00
499117 Abr Rub2 D150 P40 50X $34.00
499118 Abr Rub2 D150 P60 50X $34.00
499119 Abr Rub2 D150 P80 50X $34.00
499120 Abr Rub2 D150 P100 50X $34.00
499121 Abr Rub2 D150 P120 50X $34.00
499122 Abr Rub2 D150 P150 50X $34.00
499123 Abr Rub2 D150 P180 50X $34.00
499124 Abr Rub2 D150 P220 50X $34.00
499133 Abr Rub2 100x150 P40 50X $24.00
499134 Abr Rub2 100X150 P60 50X $24.00
499135 Abr Rub2 100X150 P80 50X $24.00
499136 Abr Rub2 100X150 P100 50X $24.00
499137 Abr Rub2 100X150 P120 50X $24.00
499138 Abr Rub2 100X150 P150 50X $24.00
499139 Abr Rub2 100X150 P180 50X $24.00
499140 Abr Rub2 100x150 P220 50X $24.00
499141 Abr Rub2 100x150 P40 10X $8.00
499142 Abr Rub2 100X150 P60 10X $8.00
499143 Abr Rub2 100X150 P80 10X $8.00
499144 Abr Rub2 100X150 P100 10X $8.00
499145 Abr Rub2 100X150 P120 10X $8.00
499146 Abr Rub2 100x150 P150 10X $8.00
499147 Abr Rub2 100x150 P180 10X $8.00
499148 Abr Rub2 100x150 P220 10X $8.00
499161 Abr Rub2 93x93 P40 50X $18.00
499162 Abr Rub2 93x93 P60 50X $18.00
499163 Abr Rub2 93x93 P80 50X $18.00
499164 Abr Rub2 93x93 P100 50X $18.00
499165 Abr Rub2 93x93 P120 50X $18.00
499166 Abr Rub2 93x93 P150 50X $18.00
499167 Abr Rub2 93x93 P180 50X $18.00
499168 Abr Rub2 93x93 P220 50X $18.00
499170 Abr Rubin2 93x93 P60 10X $6.00
499171 Abr Rubin2 93x93 P80 10X $6.00
499172 Abr Rubin2 93x93 P100 10X $6.00
499173 Abr Rubin2 93x93 P120 10X $6.00
499257 Interface Pad D150 2X $22.00
499325 Multifunction Stool MFH 1000 $350.00
499412 Charger TCL3 $155.00
499475 Jigsaw blade S105/4FSG 20X $55.00
499476 Jigsaw blade S75/4FSG 5X $14.00
499477 Jigsaw blade S105/4FSG 5X $18.00
499478 Jigsaw blade S145/4FSG 5X $25.00
499550 SYS-ToolBox2 $59.00
499621 SYS-MIDI 3 TL $85.00
499622 Systainer SYS Mini empty $25.00
499634 Abr Granat D225 P40 25X $36.00
499635 Abr Granat D225 P60 25X $36.00
499636 Abr Granat D225 P80 25X $36.00
499637 Abr Granat D225 P100 25X $36.00
499638 Abr Granat D225 P120 25X $36.00
499639 Abr Granat D225 P150 25X $36.00
499640 Abr Granat D225 P180 25X $36.00
499641 Abr Granat D225 P220 25X $36.00
499642 Abr Granat D225 P240 25X $36.00
499643 Abr Granat D225 P320 25X $36.00
499730 Syslite 4 pack $700.00
499742 Hose D32/27 3.5 AS w/Angl.Adp $142.00
499848 Battery 15V 4.2Ah Li-Ion $94.00
499849 Battery 18V 4.2Ah Li-Ion $110.00
499901 SYS-Storage Box SYS-SB $90.00
500076 SYS-MFT TLOC $75.00
500173 Zobo Bits - Metric (5 pc) $225.00
500174 Zobo Bits - Imperial (5 pc) $225.00
561287 KS120 EB Miter saw $1,400.00
561438 Circular Saw TS 75 EQ $725.00
561443 Jigsaw TRION PS 300 EQ $275.00
561455 Jigsaw TRION PSB 300 EQ $275.00
561556 Circular Saw TS 55 REQ $615.00
561593 Jigsaw CARVEX PS 420 EBQ $350.00
561608 Jigsaw CARVEX PSB 420 EBQ $350.00
561668 Jigsaw CARVEX PSC420 EB $550.00
561677 Jigsaw CARVEX PSBC 420 EB $550.00
561689 Jigsaw CARVEX PSC 420 EB Basic $350.00
561690 Jigsaw CARVEX PSBC 420EB Basic $350.00
564040 Charger MC 15 $235.00
564261 CXS Compact Drill Li 1.5Ah $245.00
564274 CXS Compact Drill Set Li 1.5Ah $295.00
564370 Cordless Drill C15 Li 3.0 $460.00
564374 Cordless Drill C15 Li 3.0 Set $585.00
564521 Cordless Drill T15 Li 4.2 $460.00
564522 Cordless Drill T15 Li 4.2 Set $585.00
564523 Cordless Drill T18 Li 4.2 $510.00
564524 Cordless Drill T18 Li 4.2 Set $635.00
564525 Cordless Imp. Drill TI15 Li4.2 $525.00
564526 Cordless Imp. Drill TI15 Basic $350.00
567696 Orbital 1/2 sheet sander RS 2 $395.00
567852 Linear sander LS 130 $395.00
567856 Delta Sander DX 93 $325.00
567863 Orbital rect. sander RTS 400 $245.00
567871 Orbital delta sander DTS 400 $245.00
570779 Rotary polisher RAP150 FE $465.00
570789 4.5" Rotary Sander RAS 115 TL $325.00
571579 Drywall Sander Planex LHS 225 $1,100.00
571782 5" Dual Mode Sander RO 125 TL $465.00
571810 6" Dual Mode Sander RO 150 FEQ $565.00
571817 5" Random Orbit Sander ETS 125 $195.00
571823 3.5 dual mode sander RO 90 DX $415.00
571903 6" Rand. Orb. Sander ETS 150/3 $345.00
571916 6" Rand. Orb. Sander ETS 150/5 $345.00
574332 Domino Joiner DF 500 $850.00
574339 Router OF 1010 EQ $435.00
574342 Router OF 1400 EQ $535.00
574354 Router OF 2200 $885.00
574368 Router MFK 700EQ Set $525.00
574422 Domino Joiner DF 700 $1,250.00
574432 Domino Joiner DF 500 Set $925.00
574447 Domino Joiner DF 700 Set $1,325.00
574553 Planer HL 850 E $615.00
583129 Pocket StickFix hand sanding $16.00
583290 Hole drilling set $241.00
583492 Dust Extractor CT 26 HEPA $625.00
583493 Dust Extractor CT 36 HEPA $675.00
584014 Dust Extractor CT 36 AC $800.00
584084 Dust Extractor CT 48 HEPA $725.00
584100 Hole drilling set in systainer $495.00
584156 Dust Extractor CT MINI $450.00
584165 Dust Extractor CT MIDI $495.00
691124 Air Sander LEX 2 185/7 $510.00
691132 Air Sander LEX 2 150/7 $430.00
691134 Air Sander LEX 2 150/3 $430.00
9397 Adapter 3/8 ISO f. Air System $14.00
M0102 Kapex blade set $195.00
M0114 CT26/36 Boom Arm Set $365.00
M0122 Jigsaw Blade 35-pack $50.00
M0124 CT48 Boom Arm Set $365.00
M0595 Hand Sanding Block Set $75.00
P00108 Parallel guide extension set $325.00
P00109 CMS-VL MFT/3 Router Table Set $1,325.00
P00110 CMS-VL MFT/3 Router Table $1,025.00
P00111 CMS-GE Router Table Set $1,625.00
P00112 CMS-GE Router Table $1,225.00
P26561287 Package Kapex + CT 26 $1,962.50
P26561438 Package TS 75 + CT 26 $1,287.50
P26561443 Package PS 300 + CT 26 $837.50
P26561455 Package PSB 300 + CT 26 $837.50
P26561556 Package TS55REQ + CT 26 $1,177.50
P26561593 Package PS 420 + CT 26 $912.50
P26561608 Package PSB 420 + CT 26 $912.50
P26561668 Package PS 420 + CT 26 $1,112.50
P26561677 Package PSB 420 + CT 26 $1,112.50
P26567696 Package RS 2 + CT 26 $957.50
P26567852 Package LS 130 + CT 26 $957.50
P26567856 Package DX 93 + CT 26 $887.50
P26567863 Package RTS 400 + CT 26 $807.50
P26567871 Package DTS 400 + CT 26 $807.50
P26570789 Package RAS 115 + CT 26 $887.50
P26571579 Package Planex + CT 26 $1,662.50
P26571782 Package RO 125 + CT 26 $1,027.50
P26571810 Package RO 150 + C
OK, got'em listed with old price, new price, % increase and $ difference.
Just copied ToolNut's price table from their site into Numbers.  Looks like the average increase is about 3.4% (just averaging the increase % column).  While nobody wants price increases on an already premium product, it is on par with cost of living increases, I guess.
That being said, I will be picking up another MFT and my RO150 before the increases hit.  This will save me $40-$50 over buying them later.
Fun Fact:  If you bought one of everything on the list, your truck would need insurance for $315,266.21 worth of stuff.  Well, $325,660.71 after April 1 [eek] [eek]
The things that are on my wishlist are either staying the same (Carvex, Carvex accessory kit, and blade kit) or are going down in price (MFK 700 set, quick clamps).  So I guess I can relax [cool]
