Hi all,
I discovered the tip to reset carvex blade holder, as shown here :
but there's absolutly no way for me to get the same result with mine. Here is a test :
I can leave it turned on for ages, but never the shaft goes up by itself.... I have to do it manually everytime. Even sometimes I have to push quite hard, and I really don't like having to do that ...... for the machine of course but also for the blade !
You can see on the video the blade's signs position : first they are below the roller, and after i've pushed back the blade manually, they are above rollers...
Is it a stroboscopic illusion or does it means that I have basically two positions with my Carvex, in other words with my pendulum starting from the top, OR from the bottom. These two positions wouldn't give me the same cut depth obviously.
I'm afraid the first position uses prematurely the roller, the shaft and it's clamp support since it must beat more than usual the roller.
Any thought ?
Mathias
Any thought ?
Mathias
