Pull out Hamper / Basket
semenza
Festool Moderator
Festool Moderator
Fingerlakes Region NYS
Trying to find a particular metal basket pullout hamper. It is white wire basket aprox. 15" tall 18" x 18" square. It is mounted to metal roller type drawer runners ( not ball bearing slides). And can be lifted off the runners. I think the drawer member is attached to the basket. The runners are connected by a couple metal cross pieces and whole unit just screws to the cabinet bottom.
I found a ton of pullout baskets and such with internet searches. But I am after this particular unit. It meets all the parameters I need and I can not find another one that will do the job.
Sorry no picture. I will try to get a pic to add later.
It's not Reva Shelf or at least not a current one.  The key to what is different about the one I am looking for is that it does not use ball bearing slides. It uses the drawer runner / slides that have the little "wheels".
The latter part I'm sure of.    I haven't seen partial ext. runners on accessories for at least a decade now, prob. longer.
I'm betting you'll have to cobble together your own kit from various separate parts to get what you want.  Might try ebay and get lucky though.
Could always do a reverse image search on Tineye to find a retailer if you had a photo of this thing.
tjbnwi said:
Are these the type of slide you're referring to? If so, I doubt you'll find a supplier made pullout using these anymore.
https://www.knapeandvogt.com/1805?
    Yes, that is the type.  Yeah, I was just hoping to find it even though it is out dated / likely discontinued. Other things can be made to work but that older type would be perfect for the customer's situation.
    Probably end up going a similar but different direction.
  Yeah, that might be worth a try.  [thumbs up]
    I think it is interesting that I have not come up with a single picture of one in searches. Usually even older discontinued things show up in searches because somebody at some point took a picture of it.  [huh]
guybo said:
Hi, I think might be what you are looking for [member=1619]SRSemenza[/member]  https://www.build.com/easy-track-1308/s1084876?uid=2609140&searchId=X1ihHeTkXP
That's very similar to the Swedish line of Elfa products.
I made a storage box on small wheels that rides in a wooden track. The track itself has 45º shoulders on each side to keep the wheels centered.
[attachimg=2]
Another option if you fabricate your own, is to use the flanged wheels from a dishwasher. When the lower rack is fully loaded with large pots and cast iron pans it's probably loaded to 30-40 pounds.
[attachimg=3]
