I like to work on small projects (I'm a novice, with tools) around the house and now that our wood floors are in, I'm going to work on the baseboard trim. I'd like to scribe the baseboard and I was wondering what would be the best method to trim off the excess area. I have a choice of LDF and pine (although the pine is significantly more expensive, so I'm considering sticking with LDF unless it proves too difficult or time-consuming to work with). My question is should I cut the bottom of the LDF baseboards with the TS55 at a 45 degree angle and then sand or plane the remaining amount to the scribed line? This would mean that I would have to cut every baseboard lengthwise and this would be time-consuming, but I would save time on sanding. Or should I just sand or plane to the scribe line and skip the saw -- this would mean sanding/planing significant amounts of LDF? Or should I buy the Quickscribe and use it with my Bosch laminate trimmer and scribe the bottom of the board after I've tacked it up an inch from the floor? I'm bothered by the amount of dust this would produce (since the Quickscribe is only made for a select few trimmers) and I wonder if dealing with real wood would be better? I've been pondering this for a few weeks that I will never get this started!
I have the MFT3, TS55, Trion -- I plan on renting a miter saw.
Any advice would be appreciated.
Liz
Liz
