I need some advice regarding sanding the topcoat of Arm-R-Seal finish. I have applied 4 coats of finish on my tabletop and there are some areas where I sanded a little heavy on my last application. I had to go a little deeper in some areas to sand out some streaking. Should I sand the entire top as deep as I sanded some areas or will a couple coats sprayed on cover up everything?
