Yes, the bit that comes with the DF500 is a 5mm and should be marked as such on the bit itself.
You need to use the corresponding 4mm bit with the 4mm tenons. Also be aware that the 4mm bit plunges 10mm less than the indicated setting, so "20" becomes a plunge of 10mm
