I’ve been eyeing the LR32 system and believe I correctly understand that you can use the longitudinal stops to position you first hole at any of 9.5MM, 16MM & 32MM from the top/bottom edge of your work piece at whatever depth from the front you choose.
My question is what happens if you put (what I presume to be) the 4th / blank side of the longitudinal stop “up & out”? Any chance it simply shifts the 9.5MM registration point by 16MM to 25.5MM the same way you can shift between 16MM and 32MM? That would be an ideal outcome for the cabinet style I am thinking of building. But if it doesn’t work out to 25.5MM, anyone have any suggestions on how to lobby Festool to make a different part that would allow for that registration shift?
Many thanks in advance for any and all information you may be able to provide.
