promark747
- Jan 9, 2010
Just received a Trion from the recon sale, and am trying to figure out whether there is an issue with the way the Fastfix is holding the blades, or if there is a problem with the carbide glides (or if it's user error...). I saw the video by Brian Sedgely regarding how to adjust the guides, and the problem is that I cannot get the saw blade to go between the rear/parallel section of the guides. Therefore I am unable to tighten the guides enough to hold the blade (which I know then must be backed off for the proper spacing). The blade will only go as far as the "V" shaped entrance, which of course cannot be tightened enough to hold the blade. I made sure to pull the blade to its furthest position downward and have tried all orbit positions.
I also wonder if another warning sign is that regardless of the position of the orbital switch, the rear thrust bearing never reaches the rear of the blade...there is always a gap. Shouldn't it be able to touch the blade?
Here is a picture of the carbide guides and how the blade is sitting in the "V" section.
[attachimg=#]
So in general, it seems as though the blade is too far forward. Wondering if this is normal or if it is an easy fix (I've tried loosening the guide's torx screw and carefully centering the guides) or whether Service should be called. I also think the blade is off-center with respect to the base opening, but I thought maybe that is the way it is designed so that the pointer on the splintergard lines up with the edge of the blade and not the center of the blade. Is this correct or should the blade be centered?
Thanks,
Brian
[attachimg=#]
Thanks,
Brian
