Quick tip for UJK rail clips
promark747
The more I use these guide rail clips, the more I like them.  Since I usually have my Parf dogs located in the same two holes in my top, I've found that capturing the clips in their respective positions on the rail (with a t-nut and screw) saves me the installation time.  It's only a few seconds each time, but it adds up.  Plus, I never have to worry about misplacing them.
That is a brilliant tip. The freedom of movement v tightness of fit varies very slightly across rails - certainly with the 4 or 5 rails that I have.
I really like this idea and will use it on my own setup the next time I use it.
Many thanks.
Great idea [member=7714]promark747[/member] - Do you remember what size screw and t-nut you used?
A quick update on this product...
I had had some discussion with Axminster about several designs for clips to secure the guide rail to the Parf Dogs. This design is theirs and I conceded to them that it was simpler and easier than any of my ideas. As a result I have agreed that the name "Parf" may be used in its marketing.
I think it was a 1/4-20 t-nut and 1/4-20 x 1/2" screw, but I'll double check.
Edit: confirmed that the t-nut and screw are 1/4-20, but the screw is 1/4".  Looks like I used a hacksaw to shorten the shaft to 1/4".
Thank you very much for checking and confirming!  I want to copy your excellent idea.
