Floor is raised 300mm from existing bed. It is inset back so I can still utilise the side step and rear step. Best of all it will allow 15 sheets @18mm to stow underneath.
Floor is raised 300mm from existing bed. It is inset back so I can still utilize the side step and rear step. Best of all it will allow 15 sheets @18mm to stow underneath.
what is the size of your Transit? - roof height? - wheelbase -?
how long have you been using this general set-up?
what would you change if you had to start over?
