bellchippy
- Aug 27, 2007
Anybody got a CMS-OF router table and leg stand, if so is it worth the almost ?800 price tag.
Any information would be welcome.
gasman said:I have an old Basis table, but the newer CMS-OF insert together with an OF2200...
My 2200 did have to go back to festool as it is usually inverted and the collet locking mechanism jammed with all the sawdust. They have fitted a mod now and it works fine again
I can only say I am constantly thrilled and surprised by how well it poerforms. It is absolutely solid, easy to adjust, the above table height adjustment is super-accurate and a delight, dust extraction is excellent. I have used it for anything from very small 2 mm grooving, up to making large fielded panels with a 95 mm raised panel cutter and it does both very well indeed. I know that people can be sceptical about just how good a router table could be, but I had a quite good Elu router table before which was quite well made and solid and the difference is unbelievable. My 2200 did have to go back to festool as it is usually inverted and the collet locking mechanism jammed with all the sawdust. They have fitted a mod now and it works fine again
Best wishes to you - but I think it is great
Hi gasman I notice on the festool UK website they say the Max cutter diameter is 60mm, did you raise the cutter above the
table and clamp on a false table ,or is the hole in the table big enough toto use a 95mm raised panel cutter.
thanks
gasman said:Forrest I am afraid I do not know what they did.... but they did tell me it was a part change. Festool UK are, as has been said before on this forum, not the most customer-friendly bunch and to be honest I was delighted to get it back within a week in good shape with the mod. If any Festool dealers know what was done - do spill the beans!
