Reasonable source for 1/2"-12 (no typo) RH and LH threaded nuts?
PaulMarcel
Arizona
My Delta bench grinder uses BSW 1/2"-12 (yes, 12, not 13...) threading on the arbors and I'd like to take off the "quick nut" thing with foldable wings that are ridiculously difficult to bend so you can quickly change them.
British Fasteners has the RH and LH versions available. But looking for other options. The right-hand threaded version is available through Amazon for $8. It's the LH that's a unicorn.
McMaster had some priced around $40 each  [eek]
Delta's site doesn't seem to have a replacement parts section. The site is pretty lame tbh. eReplacementParts who resells OEM parts shows they are all discontinued. Nothing at Fastenal or Grainger.
Starting to wonder if I should McGyver these "quick nuts" [hmm]
Hi, there is a fastenal  sky harbor business park,on their web site they had both rh and lh,@13-16 $per
12” of 7/8 hex bar, one 1/2-12 RH tap, one 1/2-12 LH tap. Supply for life.
I forgot which machine I needed a 1/2-12 LH for, having a metal lathe and some hex bar on the shelf I single point threaded a couple of nuts.
I had to turn fittings when I set up my new compressor. I wanted to hard tube the various devices instead of plastic tubing. All of the fittings were BPS, the Machinists Handbook showed the flank angle as 55º…………great. It was fun grinding a 55º single point threading tool and remembering to set the compound to 27º.
Yeah, I got excited when I saw that on their page, too, then realized they were all hits for 1 1/2"  [blink]
I was considering that as well. We'll see if I got that route; I mostly listen to metal, not work it very well
https://www.google.com/search?q=BSW+1%2F2%22-12+LH+nut&client=safari&sca_esv=567ab18d067741e3&channel=mac_bm&ei=RCSLZ4mKKeyIkPIP0vbIqAM&ved=0ahUKEwiJvKORrv6KAxVsBEQIHVI7EjUQ4dUDCBA&uact=5&oq=BSW+1%2F2%22-12+LH+nut&gs_lp=Egxnd3Mtd2l6LXNlcnAiEkJTVyAxLzIiLTEyIExIIG51dDIFECEYoAEyBRAhGKABMgUQIRigATIFECEYoAEyBRAhGKABSIMvUO4UWMQrcAF4AJABAJgBcKAB9wOqAQM3LjG4AQPIAQD4AQGYAgigAoIEwgIKEAAYsAMY1gQYR8ICBRAhGKsCmAMAiAYBkAYFkgcDNy4xoAfyHw&sclient=gws-wiz-serp
Best of luck
I googled “British fastener, nut and bolt sellers”.
A promising site:
https://britishfasteners.com/?srsltid=AfmBOoo6Eiyjl1vgBPS9KiqeVWU2MRKB8j2kK2rv2X7qF3ANJ_XSmZyk
And my search:
https://www.google.com/search?q=bri...ellers&ie=utf-8&oe=utf-8&client=firefox-b-1-m
And Toolbank, UK was a Delta distributor in the UK.  I don’t think they are anymore.  But they might be able to direct you to a vendor.
In any case, you likely will have to shop from a store in the UK.  Maybe check Amazon.uk?  Shipping through Amazon is quite reasonable and I would check there first. I’ve bought from Amazon.uk in the past and I got my stuff in about one week.
https://bhl.co.uk/brands/toolbank.html?layered_filter_brands=7253&p=2
How about a LH Die?
https://britishfasteners.com/bsc-cei-1-2-20-left-hand-die-5668.html
Around 52.00 plus S&H I presume.
?c=1
BSC - CEI 1/2"-20 LH TAPER TAP
$29.50
This ^ would suit your needs better. https://britishfasteners.com/tap-bsc-cei-1-2-20-left-hand-taper-5669.html
That was my first though too, but the cost of all of that, to never need it again, is a bit over the top.
If it was something that you might need again (or be the local source for others) it would definitely be worth it.
I think I would check with local machine shops. That option might be a bit spendy too. It might be worth having a couple of each made though. The set-up is the real cost. Beyond that, making more doesn't add much too it.
