Julian Tracy
- Oct 25, 2007
Have had an older C12 kit for some time now and the batteries are beyond spent. I could charge them both and use for a bit, but they'd be dead the next day. Unfortunately, Festool's recent battery price reductions have not trickled down to the older C12 packs, and the Festool replacements are about $80 each!
So, I hadn't really been using the kit much unless I had a specific install requiring the 90 degree or offset chucks. But yesterday I remembered I had a couple of new Skil(Bosch) 12volt battery packs sitting around that I bought on clearance years and years ago.
The Festool C12 packs are pretty easy to take apart and after soldering the new cells together in the same arrangement and then soldering the contacts/temp sensor into place the newly rebuilt packs went back together and it worked!
I had suspected that it might have just been a waste of effort as the replacement cells, though new, are quite old. But the packs charged up as you would expect and metered at 13.84volts fresh off the charger and seem to have plenty of power. Cool!
The C12 drill is built like a tank - it's as heavy as my new Makita heavy duty hammer drill, or at least it seems like it. But it's got a lot of raw power behind it and I've always been very impressed at the precise speed control it seems to offer.
The entire kit has nine more lives....
JT
JT
