I'm having a problem burining router bits when cutting BB plywood with the OF1400. Dados are the biggest problem--the bit loses its edge quickly, and I get cuts that are progresssively more ragged. Even doing a 6mm x 6mm groove with three passes is difficult. I think the glue is responsible for this--fouling the cutter, which then runs hotter and delivers an inferior cut. Can anyone recommend a brand or type of router bit that would work well in this material? I'm also concerned about the Domino cutters wearing out prematurely. Has anyone had a problem with this?
