I'm looking to refinish the log cabin siding on my house. I don't have a picture of the actual condition at my house, but here's basically what's on the side of my house:
[attachimg=#]
It's 2x8 pine siding, so it's not actually a log cabin, but it has a bit of a curve to it. There's square stock in the corner boards, and flat trim around the windows (painted). It hasn't been stained in quite a while (some fading, especially where exposed to the sun), there are a few water marks in some areas, etc.
Inspired by the SysNotes for May 2008 and a post here from Frank Pellow about resoring the exterior of a cedar cabin, I thought I'd ask my opinion on what Festool tools might work.
House is a little over 1000 square feet (92.9 square meters), not counting the garage. One story, should be easily reached by ladders. I don't own a CT vac, as I've been getting away with a wet/dry vac on my TS 55. I do have a random orbit sander from the local home improvement store, but that's about it.
I've thought about the Rotex RO 150 (with 496647 Interface Pad) to get the bulk of it sanded. Also, I'm considering the RO 90 (possibly with the 497481 Interface Pad) for harder to reach places (not much more than the DX 93 E, with similar use with the triangular head). The articles I linked to above also used the LS 130 EQ Linear Sander, but I'm trying to keep costs down (can't buy all three). Would the LS 130 be ideal for the bulk of the work, rather than the RO 150? If I went with the LS 130, should I go with the DIY profile kit? Or would the RO 150 with interface pad be sufficient? What about using an oscillating multi tool (which I already own) with sanding pads for the detail work in the little nooks and crannies?
Also, any suggestions on what to stain/finish it with when finished? I'm looking fore something close to a cedar color, probably semi-transparent, with good UV resistance. My guess is the wood will be pretty thirsty, so it might need a few coats.
[attachimg=#]
