TheHobbyist
- Sep 19, 2011
I'm new to home renovation so bear with me. I have both an RO 125 and RO 90. My wife tasked me with sanding the stair risers and stringer sides. Both the riser and stringers are painted with exposed hardwood treads. I am not sanding the treads...yet.
I used Cristal P80 sandpaper and am going through it much too quickly. As I put on a new pad it's removing the paint fairly quickly. However, before I even finish the riser it seems to almost stop removing the paint. I don't know if I'm using the wrong paper, grit, misusing the sander or what. Bottom line, one pad doesn't even seem to finish a single riser. Just in case you ask, I can't tell how many coats of paint were on these stairs nor type of paint.
Should I use a different paper type (e.g. Brilliant2 or Granat)? What about the grit number? I'd also appreciate feedback on how I might be using the RO 125 incorrectly on a vertical surface. Keep in mind it's somewhat constrained space as the RO 125 is so large I have maybe a 1" clearance beyond the diameter of the sander when placed at top of bottom tread measured to bottom of upper tread.
I have the RO 125 connected to a CT26 with vacuum set to about 50%. I've tried the RO 125 at speeds varying from 2 to 5.
Would appreciate any professional help!
