squall_line
- Feb 17, 2021
My wife and I acquired a full bedroom set from her grandmother when we moved her out of her house. It's a mid-century modern set, neutral color wood (oak or ash?), etc. etc.; pretty much the exact aesthetic I was looking for, and it kept the set in the family.
It's not a major brand or a rare piece like Piersall or anything like that, but it's in good shape other than the veneer tops.
The veneer has dried out significantly (as seems typical for furniture we usually find from that era) to the point where it will cath a fingernail but isn't actually curling or anything horrible like that.
We plan to use the lowboy dresser as a changing table for our soon-to-be, and I want to make sure it's protected from liquids. The highboy is in similar shape and won't see liquids in the near-term, but may in the future with plants, drinks, etc. The MCM lowboy we have in the other nursery has a laminate top, which has made it such an easy surface to maintain as a changing table.
Refinishing options and concerns:
Option: Sand with 220 grit, seal the top
Concern: I'll sand through the veneer before I knock down the high spots
Option: Shellac/poly the heck out of the top and build up a finish until it's flat and sealed
Concern: Bleeding/uneven staining, dissolving the glue and lifting the veneer
Option: Remove and replace the veneer
Concern: Not in my wheelhouse, not much time to do that
Option: Remove the veneer and replace with laminate (wood-look laminate is period correct for some MCM furniture)
Concern: Time isn't on our side; finding the right shade of laminate may be tough, WAF may not be high (she appreciates the ease of use of the other lowboy, but prefers real wood)
Any thoughts or recommendations on a path forward?
