Just bough a used ETS 125 EQ and if the vibration seems fine the rotation is very very slow as you can see here :
The carbon brushes are fine.
I was wondering if I should change the bearings but was enabled to unscrew the bolt holding the conversion kit.
I also notice that without the pad the motor was rotating much more freely than when attached, so could the collar be the problem ?
Thank you for your help View attachment 1
