RichLine 18-7-TT and 18-HM Mortise & Tenon Machines w/ Tilt Tables - MINT
GURRIE
Machine #1
Mortising Machine 18-8 HM with Extra Tilting Table
I bought this machine NEW for $2,704 less than one year ago.
It has been used to make exactly 32 mortises for a set of Chippendale chairs.
Description:
This machine will cut a very clean round end mortise in less than 30 seconds.
The machine comes with a Porter Cable 8902 2 1/4 HP.
The machine is easy to set up and it has adjustable right and left hand stops and adjustable down stop.
Remove the clamping mechanism and mount your own clamping fixture for that special mortise project such as curved chair backs, round plant stands, etc.
Specifications:
•All cast iron construction
•Adjustable stops
•Self-lubricating linear bearings
•Table tilts up to 30 degrees
Machine Size: 18" x 16" x 31" high - Machine Weight 170 lbs.
Machine is mounted on a beautiful cast aluminum rugged table (see photos on RichLine website)
The extra tilting table allows for making superb mortises in double angled chairs post, rails etc.
Unbelieveably accurate locations and cuts.
Machine #2
Tenon Machine with Tilting Table & Rotating Head 18-7-TT
I bought this machine NEW for $2,944 less than one year ago.
It has been used to make exactly 32 tenons for a set of Chippendale chairs.
This machine cuts a very clean round end tenon in less than 30 seconds without the use of a template.
Max size with standard set up is 1/2" x 2" x 8" wide.
The machine comes with a Porter Cable 8802 2 1/4 HP router.
This machine is easy to set up and it has adjustable right and left hand stops.
The tilting table is a must when making chairs or any furniture requiring a compound angled tenon.
The table has 3 fence settings: right, left and center.
The fence can be angled 15 degrees right or left.
Specifications:
•Adjustable stops
Table Size:  12" x 10"
Approximate weight 176 lbs.
Total Cost of both machines NEW was $5598.
Retiring and selling my entire woodshop machines and tools.
Ed Gurrie
email me at edwood44@hotmail.com or
call 978-857-2013 if interested
Asking $4200
Check the RichLine website at
http://richlinemachines.com/machines.html
Local Pickup or Common Carrier Freight arrangements made by the buyer.
