Right Angle Adapter for CT36
Bell407
Does Festool make a 90-degree elbow that I can use coming off my CT36 and then into the female end of the 50mm fitting? My CT36 is configured with a boom arm and would like to get the 50mm hose turned toward the back of the CT and up the boom more quickly. It would also keep some of the hose from sticking out into my work path.
I would like a 36mm one but from what I have seen only a 27 mm is available.
Sparky - I too have only seen the elbow that steps down from 36mm to 27mm.  I actually need to come out of the CT36 (50mm?) directly into the female end of the 50mm hose that comes with the boom arm.  So it is a 50mm to 50mm 90-degree elbow with both ends being male.  No worries if this doesn't exist.  I may be able to find a standard PVC plumbing or electrical elbow that is close and just file down or build up (tape) diameters.
