Greg M
- Jul 13, 2014
I just recently bought an RO 125 through the recon sale. I've used it less than 2 hours, probably not even an hour. Tonight I was sanding some boards and I started getting a little wobble and then the pad just came apart.
Is this normal or is it something that rarely happens? I'm wondering if I should keep several pads on the shelf just in case. Fortunately I was on the last board so I finished the rough sanding with my ETS 125, just took a little longer.
I hope this isn't normal because then this sander is going to be expensive to use.
