RO 90 - Edge protector size versus Window protector set
mwildt
Curious what size the edge protector, that comes with the RO 90, is compared to the window set 497936. Will it correspond to any of those in the set ? How close will the pad get to the edge when using these ?
Michael
The 3 piece set's sizes are all different from the standard one that comes with the RO 90. The standard has a zero offset so that you can sand right up to the edge, and the 3 piece set have sizes something like 5 mm, 10 mm and 15 mm, not exactly sure about those dimensions, but something along those lines.
That I know of, there isn't a window set for the RO-125 at least in NA.  The edge of the RO-125 edge guide is fairly wide; seems like you could double-stick tape something to the edge to give the offset you want.  If it's needed enough, retrofit a few using cyanoacrylate.
