hcoyote
- Dec 8, 2013
Hello,
Tonight, I was working on a new breadboard containing various hardwoods. I was sanding down both sides, going from 80, to 120, to 180, to 220 grit in rotary mode, running for maybe a total of 20-25 minutes with some breaks in between for flipping the board and changing out grits. I noticed about half-way through that the body of the sander was getting uncomfortably warm. When I noticed it, I realized my CT was running at half speed, so I turned it all the way down, thinking that the extra suction might have been causing it to do more work than necessary. I wasn't applying much pressure to it all, just enough to control direction of my passes.
Is this normal? The RO is about 6-8 months old and only has a few hours of use on it (I think enough to break in the contacts on the motor).
Travis
Travis
