ROb McGilp
- Apr 5, 2007
Hi
On Monday, I used the RO150FEQ to heat seal 3 different oils into one piece of Red Gum. There is no wax, poly or other finish involved, just straight oil and sanding. If you follow the darker grain through the three oils, it becomes clear that you lose a lot of the grain pattern in the Danish oil, while keeping it in both the China Wood and Scandinavian oils. The SO also gives a brighter appearance than both the other oils and is definitely darker. I'm wondering if the use of a 150/3 would help lift the finish on the DO or not. Any ideas?
Pic 3 is to show how much presence the heat sealing brings to a piece. Hopefully its clear.
Regards,
Ulbrecht
Regards,
Ulbrecht
