Rockler Table Saw Small Parts Sled
rvieceli
Carbondale Illinois
I picked this up a while back to use for cutting the small inlays I use on most of my projects. Using the regular miter gauge my fingers were getting uncomfortably close to the blade. Finally got around to assembling it.
https://www.rockler.com/rockler-table-saw-small-parts-sled
It went together quickly and works great. Has a t slot for clamps, so no more finger clamps. 👍
When you order also pick up a couple of t slot camps if you need them. I got these.
https://www.rockler.com/mini-deluxe-hold-down-clamp
https://www.rockler.com/hold-down-clamp-5-1-2l-x-1-1-8w
Ron
[member=3192]rvieceli[/member] - your post is a really helpful reminder to all and especially to less experienced woodworkers:
    Machinists use workholding automatically.
    Woodworker not so much - at least until they have a few close calls.
The ROCKLER example appears to be a good one and something similar can be shop built for special applications . Applies to Router Tables as well.
Woodpeckers Drill Press Table also deserves mention in this connection.
thanks for sharing
Hans
thanks for sharing
Hans
Timely right, for me at least.. a set back caused by something not so frightening; namely a stationary belt sander which did off my fingerprint on my left ring finger. Watch out and use “things” instead of your fingers.  [big grin]
I'm eyeing something similar: Microjig 360 sled kit, seen in a recent issue of Fine Woodworking, which allows numerous user-built set-ups to be made including a cross-cut sled, an angled sled, a circle jig, a tenon jig, etc.
