HawaiianBrian
- Jun 18, 2017
I bought the Rotex 150 FEQ and the CT26 Dust Extractor recently and for its maiden voyage I sanded a small Monkey Pod slab table that needed to be refinished. There was no finish on the wood when I started sanding with the rotex. After just a few minutes of sanding with some 150 grit I noticed lots of saw dust on the surface of the table, I turned the sander over and the sand paper was totally clogged with sawdust. Is this normal? In the past I've used a Dewalt sander hooked up to my shop vac and I've never had saw dust build up like that. I had the vacuum on high and was sanding on med speed, hopefully this is just user error that can be corrected by tweaking some settings or something. I've done some google searches to find some tutorial videos for the Rotex that may be helpful but i'm not finding anything. Any help would be greatly appreciated.
