Hello all. I have owned my Rotex 150 for about a year and a half now I think and really like it. I was introduced to it by a guy that does a lot of slab tables (mostly walnut and maple, but others). His method of sanding was to start at 60 or 80 grit depending on the roughness of the slab, use Rotex mode all the way up to 220. Then he would switch to a Makita 5" ROS and start all over from 80-220. He said the 5mm stroke of the Rotex in ROS mode produced too noticeable of a pattern. He typically finishes with a satin conversion varnish. To me, this seems like a lot of wasted steps with the ROS, but that's how he rolled and the finish was fine. However, I am wondering what most Rotex users do in similar situations. I have watched a lot of videos to see what others are doing, read many posts, but see a huge variance in what people actually do. I also watched the "Larry Smith" video that never used the ROS mode at all but went up to a polish surface using the Surfax products. So, am a bit confused what a good sanding process is, blending both the geared and ROS modes.
Also, I have been contemplating getting a dedicated finish sander, like the ETS 150/3, but am not yet convinced I really need it for my projects which are typically wood tables with either a waterborne acrylic or poly. Seems the Rotex can do it all, albeit with perhaps less finesse than a dedicated ROS.
