slopjock78
- Sep 25, 2014
I just recently obtained a lightly used OF1400, and would like to start using it for some dado work. My question is which type of router bit is best for creating dados? up spiral, down spiral, straight cut?? Does material (solid wood, ply, MDF, etc) make a difference on what type of bit to use? Does doing a rabbit vs a dado require a different bit?
up to this point i have only created dados with my table saw, so I want to make sure i am using the right bit for the job.
also, another question on technique: do you use an undersized bit, and make multiple passes, or use the correct sized bit and make one pass?
thanks for any help
thanks for any help
