Router coping sled (for Shaker cabinet rails and stiles)
Packard
Hudson Valley, NY
For many years I have been using a disposable shop-made coping sled.  It is an 8” x 8” x 3/4” piece of plywood.  I use a small bar clamp to clamp the stock to the front of the “sled”.
It was entirely satisfactory for many years.  But for reasons I cannot discern, lately I have been getting a number of bad cuts.
I am contemplating getting a commercially made coping sled.
They range in cost from $60.00 to close to $300.00.
I am hoping to find something in the $130.00 to $160.00 range.
Any recommendations?
(I am going to try a Longer piece of plywood first (8” x 16”) and see if that remedies the bad cuts.  But I think it is time for a more professional solution.
I had settled on that same Rockler sled (it got good reviews and I have free shipping).  But I am going to go back to the table saw method.
With the router I had a hard time getting grooves and stub tenons perfectly centered.  I then had to sand the surfaces flat.
With the table saw, the tenons and grooves are guaranteed to be centered.
I use a heavy cast iron tenoning jig that makes relatively quick work of the task.
The two outside blades of my dado set are just under 1/4” so two passes easily makes the 1/4” groove.
The tenoning jig holds its setup (I don’t use if for anything else), so that is quick and easy.
And the faces are always flush—no sanding require.
If I decide to get a coping sled, that Rockler one is what I will be ordering.
I have never bothered with a sled. I just use a push block behind the workpiece. It stays square and covers the back to combat tear-out. It has always worked for me.
I always did it that way too.  I used a 12” x 12” piece of plywood.  But lately I have not been getting clean results and I don’t know why.  In the past, it always worked perfectly.
As an aside, if you ever retire a wooden interior hand rail, cut off a couple of 6” long pieces and screw it to the push material (easier with my 12” x 12” plywood).  It offers excellent hand purchases and is very comfortable.  You can buy it by the foot form Home Depot, but I had an old used rail.  Set it on a slight angle towards the fence to guarantee good contact with the fence along with the forward movement.
Tom Gensmer said:
Just outside of your preferred price range, but I have not found a coping device better than the Aigner Contermax. I originally bought mine for an older router table, and still use it regularly on my shaper if I don't want to bother setting up the outrigger.
https://martin-usa.com/products/contermax/
An interesting design.  I wrote to the company for pricing and purchasing information.
Amusingly, the black handle that they have on this sled is almost certainly identical to the black handle I purchased (but never used) for my barn door.  Instead I made it from 1” diameter oak dowel and 1” wide, 10 ounce leather belting.
https://www.ebay.com/itm/1855285063...MI5s_2qIfZ_QIVia3ICh2PVQLYEAQYAyABEgKlNPD_BwE
