- Jan 22, 2007
Rick Christopherson said:Neither base is specifically intended for this usage. Only the OF2200 has a base specifically for this purpose. Given the two incorrect options for the OF1400, the small bore base is the better of the two for the reasons listed above.
grbmds said:I don't understand. Why would it be available if it isn't meant to be used in this way?
Shane Holland said:Paul, the table widener base is 10mm thick and not made for use with the guide rail. It will be 5mm too thick.
The small bore base or the support foot should be used with the guide rail to offer support. You can see the small bore base in this video around the 7:45 mark and around the 8:00 mark on the guide rail.
Support foot - http://www.festoolusa.com/power-tool-accessories/routers/other-accessories/support-foot-438608
snachlas said:I agree that it's confusing as far as using the small bore base with the guiderail. One reason I bought the small bore base is because the Festool video specifically shows and says that the base can be used instead of the foot for increased support when using the OF1400 with the guiderail.
