RTS or DTS or RS2E
MrToolJunkie
Hi everyone,
I need some advice from all the experienced users here.  I prefinished some panels and glued them into their frames for a desk I am making.  I had a "doh" moment after glue-up.  On two of the panels I did not sand very well and there are a couple of low spots that really show when the light hits it just right  [embarassed].  I need to refinish the panels and reapply the finish (just using some Watco Danish oil).  The wood is highly figured Birds-eye Maple.  Since everything is glued up (and it was a difficult glue-up), disassembly is not an option.
What sander would you all recommend is best for this task?  What paper and grits would you also suggest?  I had finished everything to 400 grit.
The panel sizes are roughly 12x18.  I need something that will get close to the edge without marring the stiles and rails.  The RS2E might be overkill for this, but it seems like a great sander long-term.  The price point of the RTS and DTS is appealing, especially since I just acquired a CT22 and Rotex 150 about a month ago.
Thanks in advance!
Scot
Scot, if you really want to level out a panel the RS2E is the best way to go. The large surface will make sure you get a straight result without dimples. For this particular task the RTS and DTS are less suitable due to their small surface.
Scott,
Just an aside, but are you not going to have some issues with the glued-up panels and wood movement? Shouldn't the panels have been left to move in their frames with just a spot of glue to hold them in the centre of the rails?
Richard.
Hi Richard,
I was not clear in my initial post -- they are floating panels -- I just glued the rails and stiles and assembeled them to the legs.  I just cannot disassemble the glue-up and I need a sander that will work on the workpiece.  I could use a RO sander for the middle of the panel, but I do not want to have witness lines (or at least minimize them) around the edges and corners.  I hope this clarifies everything.
Thanks for the replies.
Scot
After talking to Allen (my local Festool service rep) I opted for the DTS400.  I will give it a workout this week and post my results.  Tried both the RTS and DTS at the store and the DTS seemed to do a little better next to the edge than the RTS.  I can tell I am really going to like this sander -- very smooth and vibration free.  I am always amazed at the dust collection hooked up to a Festool vac -- no sanding dust whatsoever.
Scot
