- Mar 26, 2009
More info coming in the next few minutes....
Edit....
Over the coming weeks, Festool will be introducing a new abrasive designed specifically for wood applications - Rubin 2. Rubin 2 represents a gigantic step forward in abrasive technology, producing better results up to 30% faster, while lasting up to 30% longer than the original Rubin.
Finish Faster - Rubin 2 is designed to quickly shed wood fibers, eliminating clogging so the abrasive stays sharp, leading to a 30% faster removal rate
Save Money - Since Rubin 2 is designed to prevent clogging due to buildup of pitch and wood fibers, you will get up to 30% longer life out of every sheet
The Best Finish - Designed for rapid grit progression, you will spend less time going from 80 to 220, achieving the best possible finished surface in the least amount of time
Broader, More Complete Range of Grits
In addition, Festool is taking the opportunity to fill in what were formerly gaps in the abrasive range, adding 32 new grits/sizes. And not least, Rubin 2 now covers the full range of wood applications, extending from P40 all the way to P220. Stay tuned for availability.
Timing
Rubin 2 will be introduced gradually over the next few months.
Complete Reference List
For a full list of Rubin 2 item#’s and their Rubin equivalent visit Festoolproducts.com - Rubin 2.
Pricing
Rubin 2 is priced at a slight premium over Rubin, depending on pack quantity.
Edit....
Timing
Pricing
