I don't know if it is the humidity here, but my 5mm dominos barely fit and need some help in the form of a mallet to get seated.
The 6mm domino needs some serious sanding both in width and thickness or will not even think about fitting into the mortise. Even after sanding them down and seating them with a hammer, I couldn't remove them and needed to cut them flush (I wanted to change their placement).
Anyone else have this issue? Is there something I can adjust on the machine to make it cut a little wider?
