sanding pizzas
lerabotperche
Hello everyone,
I'm looking for advice to avoid theses pizzas i got from sanding kitchen workplans
I've tried various sanding discs and sanding speeds.
Some of them do not sand anything and all the others end like pizzas.
Do you know any way to avoid this sh*t ?
Thank you :)
What you have there is a phenomenon called "Corning". It is caused by (or a combination of) soft (uncured) material, too fine of a grit, wrong sanding pattern (of the machine)
That soft material could also be a very thick (multiple layers) of an old oil-based paint.
The fine grit is self-explanatory.
The pattern is the sander itself. A small-orbit DA type sander is really intended for finish sanding, just throwing a coarse grit paper on it will not do the same as it would on the correct sander.
Swapping to a geared-orbital sander will be much more aggressive. The idea is to scrape that paint out of there without re-grinding it into the rest of it. That creates heat, which glues those globs back together.
Lastly, a pure spinning machine, like a grinder with the appropriate sanding pad,  often works well too.
A lot of this depends upon the size of the area you are sanding/stripping.
I have literally stripped an entire pickup truck of years worth of enamel paint, with a 7" sander/polisher, but that is probably overkill for smaller projects.
The RAS 115 would be ideal for this, but they are sadly discontinued. There are alternatives still available though.
Next choice would be a Rotex, size depending on the project.
There are also variations in abrasives. Look for one with the intent of stripping. These are usually "Stearate" coated. This is a soap-like material that lubricates, which keeps the swarf from sticking/balling up.....corning.
Sometimes this will be a slightly different grit. Say your typical 40 grit is "open coat", the closest Stearated version might be 36 grit.
None of this is guaranteed, just check for the coating. That type of paper will perform better, no matter the grit, but they quit doing it at a certain point.
Just to add to CRG's comments, it appears you're using a 150mm Rotex, judging by the paper in your images. It also appears you're using too fine a grit and possibly not using the driven mode. Switch from random orbit to driven and use coarser paper. If you're not using dust extraction, start.
Stripping with abrasive takes a coarser grit than you might expect or want to use. 60 would be the absolute finest I would try. 40 is probably what you need. Depends on the finish. It looks gummy, which means coarser.
I don’t know what “kitchen workplans” are but the stuff is too gummy or resinous for the abrasive you’re using. Best to scrape off whatever is getting soft and sticking to the abrasive. Or use a coarser abrasive that has a coating that resists that.
I echo all of the advice given so far and would add trying some Saphir paper. It has a semi-closed coat which yields a high removal rate and good surface quality.
https://www.festoolusa.com/accessor...ir-d150/575195---stf-d15048-p36-sa25#Overview
Use dust extraction and slow down the sander. Speed causes heat which just remelts the swarf.
I've also used one of these Powertec cleaning sticks and it does a good job on keeping the disc clean.
A few shakes of Mozzarella, some passata, a few slices of pepperoni - and you’ll be good to go. Screw the woodwork and ignore the strange crunchy chemical taste of the base & crust. Crack open a few beers. Enjoy your day. Life’s too short not to.
Kevin
May be try using something else to remove the paint / coating.  e.g. heat gun or paint stripper.  Once you've removed the majority of the paint / coating then switch back to a sander.
Please can you post a picture of what you're trying to remove the paint / coating from?  Do you know what the paint / coating is?
Regards
Bob
